Results 1 to 1 of 1
Thread: Ep 04 - 18' Sailboat Build – Installing Main Frames
    Supporting Member Downeast Thunder's Avatar
    Dec 2015
    usa
    Downeast Thunder's Tools
    Boat building continues, erecting the main frames on the strongback for my new sailboat!
    This is the fourth episode of the 18’ sailboat build and is all about erecting the main frames in position on the strongback. This is not a complicated operation but does take time and shouldn’t be rushed. It’s just too easy to make several simple mistakes.
    Before mounting the main frames, I had to make several “mounts” or “jigs” of the proper height to set the main frames on and make sure they were all the proper distance apart. A more precise explanation is given in the video.
    Downeast Thunder Creations
    http://www.downeastthunder.com
    Shoestring Shipyard
    http://www.shoestringshipyard.com
    Downeast Thunder Creations Youtube Channel
    https://www.youtube.com/channel/UCUU...pKFwXTYQ57ex3g
  2. The Following User Says Thank You to Downeast Thunder For This Useful Post:
    sask man (Sep 27, 2019)
