Results 1 to 10 of 10
Thread: Engesa Boomerang walking beam suspension - video
    The Brazilian-made Engesa EE-25 utility cargo truck featuring its "Boomerang" rear axle with walking beam suspension.
    Tracked pickup truck - photo
    Hydraulic leg truck turning assist - video
    Fence washing truck attachment - GIF
  2. The Following 11 Users Say Thank You to Altair For This Useful Post:
    Andyt (Feb 14, 2019), baja (Feb 17, 2019), KustomsbyKent (Feb 14, 2019), MIGuy (Feb 16, 2019), mwmkravchenko (Feb 14, 2019), PJs (Feb 17, 2019), ranald (Feb 18, 2019), Scotty1 (Feb 13, 2019), Seedtick (Feb 13, 2019), sossol (Feb 14, 2019), Toolmaker51 (Feb 13, 2019)
    Torque +Traction +Ground Clearance =Git 'er done.
    Supporting Member Steved53's Avatar
    Apr 2018
    UK
    Steved53's Tools
    I think Scammell used a walking beam on their Pioneer trucks back in the 1930s..... With full 6 wheel drive they went nearly anywhere.Engesa Boomerang walking beam suspension - video-pioneer-6x6-trailer.jpg
  5. The Following User Says Thank You to Steved53 For This Useful Post:
    Jon (Feb 14, 2019)
    Supporting Member Radioman's Avatar
    Jun 2018
    Massachusetts
    Radioman's Tools
    Mack has been using walking beams for a century!
    From the video I can’t see exactly how the power is transmitted to each one of the rear wheels. If I had to guess I would say there’s a chain inside the walking beam transmitting power to each of the rear wheels and the chain is being powered from the center pivot point. Of course this is just MHO?
    I think the driver has to re-read the book and understand what constitutes a running start.
  7. The Following 2 Users Say Thank You to Radioman For This Useful Post:
    IAMSatisfied (Feb 17, 2019), Toolmaker51 (Feb 14, 2019)
    Dec 2014
    South Dakota
    KustomsbyKent's Tools
    That is one hell of a bad @ss truck! I want one!
    I bet a bit more weight on the rear end would actually help it get more traction for climbing. The articulation is fascinating to watch over the rough stuff.
    Thanks for sharing.
    Dec 2014
    Gone
    Quote Originally Posted by Radioman View Post
    Gear reduction boxes are mounted on the rear axle. The wheels are then mounted to the reduction box hubs. No chains were harmed. I believe Portal made those.
  10. The Following User Says Thank You to Loose Ctrl For This Useful Post:
  11. #7
    Oct 2012
    Lafayette, Indiana
    sossol's Tools
    That engine was making some beautiful noise. Sounded like a 2-stroke Diesel.
  12. #8
    One huge advantage that truck has is the single rear differential powering a motor-grader type enclosed chain drive to stubbed independent axles allowing for extreme vertical movement Another advantage over a 6 wheel drive truck with 2 rear ends is at all times both tires on either side have weight distributed to them evenly due to the power coming from the center of the walking beam this also lends for a much wider range of from front left to right rear and vice versa.
    I have little doubt that if the truck had a cargo bed with some weight in it the truck could have traversed the hill each time on the first attempt.
    Yes the engine does have a sound like that of a 2 stroke engine possibly a 6 71 Detroit . The transmission sounds like it may also have several gears with a close ratio pattern but there were times when the driver was not utilizing the sweet spot of the torque range to its full effect possibly due to not up-shifting and down shifting at the optimum times
    In my opinion the truck is a winner winner chicken dinner for a rough service off road lower speed transport vehicle. Equally as effective as a 10 times more complex modern vehicle used by the US Military 1000's fewer parts. but over all lacking in the protections and comforts the US military has become so spoiled to.
  13. #9
    Jan 2018
    Black Mountain Queensland
    ranald's Tools
    I was expecting ,with all that fun, the driver would do 6 wheeled donuts.
    Thanks for posting.
  14. #10
    Supporting Member Isambard's Avatar
    Aug 2019
    Hawke's Bay, New Zealand
    Their 6 x 6s were still being built with it in the 60s...There is one locally.
