Results 1 to 4 of 4
Thread: Easy Method for Installing Sanding Discs
    Supporting Member tmate3's Avatar
    Jan 2021
    tmate3's Tools
    This is an old trick, but some may not be familiar with it. When installing a new sanding disc, use a razor knife to cut the backing film in half across the middle. Peel off one half of the film. Then insert the half with the film still on it down against the bare plate. Stick the exposed half on, and then rotate the disc, peel off the other half, and stick it in place.
    Easy Method for Installing Sanding Discs-cut-film.jpg Easy Method for Installing Sanding Discs-peel-film.jpg Easy Method for Installing Sanding Discs-film-side-down.jpg
  2. The Following 2 Users Say Thank You to tmate3 For This Useful Post:
    finchie (Jan 20, 2021), rgsparber (Jan 20, 2021)
    Supporting Member Ed ke6bnl's Avatar
    Mar 2012
    So. California high desert
    Ed ke6bnl's Tools
    kinda the way I do it BUT I just bend over one half of the glue covering.
    1950 F1 street rod
    1949 F1 stock V8 flathead
    1948 F6 350 chevy/rest stock, no dump bed
    1953 chevy 3100 AD for 85 S10 frame going for a 4BT cummins motor, NV4500
    1968 Baha Bug with 2.2 ecotec motor, king coil-overs,P/S
    2000 National Sea Breeze 5th wheel trailer
    1998.5 Dodge 2500 4x4 Cummins,
    Better than my method; with backing off and plate clean, flex the disc concave so outsides [9 & 3 o'clock] touch first. Then lower into position until 12 o'clock is concentric.
    Thanks tmate3! We've added your Sanding Disc Installation Method to our Disc Sanders category,
    as well as to your builder page: tmate3's Homemade Tools. Your receipt:
