Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: Easy access air drain on compressor
    Oct 2019
    Sgbarker's Tools
    It’s a challenge to get to the air drain on my air compressor so I made it easier. An auto drain would be nice but they’re a little spendy
  2. The Following 16 Users Say Thank You to Sgbarker For This Useful Post:
    baja (Nov 20, 2019), Beserkleyboy (Nov 24, 2019), bobs409 (Jan 4, 2020), brianp (Nov 20, 2019), Corm (Nov 25, 2019), EnginePaul (Nov 22, 2019), IAMSatisfied (Nov 24, 2019), jdurand (Nov 20, 2019), Jon (Nov 21, 2019), Karl_H (Nov 25, 2019), lastgoodusername (Nov 26, 2019), Paul Jones (Jan 24, 2020), shopandmath (Feb 15, 2020), Toolmaker51 (Nov 24, 2019)
    Thanks Sgbarker! We've added your Air Compressor Drain Valve Extension to our Air Compressors category,
    as well as to your builder page: Sgbarker's Homemade Tools. Your receipt:
    shopandmath (Mar 1, 2020)
    May 2013
    thats a great Idea
    kngtek's Avatar
    Dec 2016
    Quote Originally Posted by Sgbarker View Post
    Great idea! I have a much smaller air compressor, but am negligent in not emptying it as frequently as I should because of lack of easy access to the water drain valve. Your idea solves the access problem.
    One of the main causes for compressor tanks going bad is the drains are so inaccessible most folks don't drain theirs regularly
    Sgbarker (Nov 21, 2019)
    Jun 2018
    Louisiana
    well done sir!
  10. The Following User Says Thank You to TrickieDickie For This Useful Post:
  11. #7
    Jun 2018
    Louisiana
    I have never understood why the manufactures do not apply a coating on the interior of pressure tanks to prevent rusting.
  12. #8
    Quote Originally Posted by TrickieDickie View Post
    yes you do. It is called dollar cost averaging for planned obsolesce.
    If you make something that will outlast the compressor or you make a compressor which will out last the tank how can you expect to sell a new one tot eh same customer ever again.
  13. The Following 2 Users Say Thank You to Frank S For This Useful Post:
    bigtrev8xl (Nov 25, 2019), bobs409 (Jan 4, 2020)
  14. #9
    Jun 2018
    Louisiana
    You are right Frank
  15. #10
    katy's Avatar
    Jul 2019
    Red Deer Alberta
    katy's Tools
    I did the same thing years ago, using 3/8" copper tubing and a 1/4" ball valve. The ball valve is much handier to operate than the original type.
  16. The Following User Says Thank You to katy For This Useful Post:
