Results 1 to 4 of 4
Thread: easy 2x4 crane for lifting an engine head
    Dec 2014
    South Dakota
    KustomsbyKent's Tools
    Here's a redneck 2x4 wood crane that I made for lifting the cylinder head back onto my CabOverEngine truck, as it is heavy, awkward, and quite a reach to get it up and in there.
    It worked quite well.
    The head is 80+ lbs and needed to be guided down over a copper oil line and also not damage the new head gasket.
  2. The Following 2 Users Say Thank You to KustomsbyKent For This Useful Post:
    Jon (Oct 1, 2020), Tooler2 (Sep 30, 2020)
    Thanks KustomsbyKent! We've added your Cylinder Head Crane to our Cranes category,
    as well as to your builder page: KustomsbyKent's Homemade Tools. Your receipt:
    KustomsbyKent (Sep 29, 2020)
    Feb 2018
    how much control do you have lowering using a ratchet strap?
    Dec 2014
    South Dakota
    Using a large ratchet strap, you can control it pretty easily. It goes slowly as you can only release about 3 ratchet clicks at a time. I also made sure to spool on enough strap when I tightened it so that I would have enough to let it down into place and not run out of release strap.
    Plus, I can take it all apart, and use the 2x4's for something else... so almost zero cost!
