Results 1 to 10 of 12
Thread: Drop test of a Sikorsky UH-60 Black Hawk helicopter - GIF
    May 2024
    nova_robotics (Dec 26, 2024), tuchie (Dec 29, 2024)
    Lake Tahoe
    IntheGroove's Tools
    Glide ratio of a streamlined crowbar...
  4. The Following 2 Users Say Thank You to IntheGroove For This Useful Post:
    BuffaloJohn (Dec 26, 2024), nova_robotics (Dec 26, 2024)
    For that helicopter to have achieved the altitude it was dropped at, in a real world the rotor blades would have been rotating in the neighborhood of 500RPM With engine fail mode autorotate the collective pitch would be between 3 and 5% The rotor speed might have increased to 120% or 600 RPM An experienced pilot would use this RPM increase to his advantage by increasing the collective pitch slowing the rate of fall enough to possibly reduce major damage to the airframe and increasing the survivability chances of the occupants.
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    So - did it pass or fail?
    It looks like to me, being an untrained helecopter pilot, that it's going to take quite a bit of buffing to make it fly again...
    Jun 2018
    Louisiana
    Yep, it broke.
    Aug 2021
    Cape Town SA
    albertq's Tools
    Not much point in that test other than to see how it breaks.
    If pilot does not react fast enough (usually within a couple of seconds) after loss of power, by lowering the collective lever to reduce blade pitch, the rotor speed will drop below a recoverable RPM and the rotors will stall. In that case it will end the same way as this demo.
    As Frank said, in a real world scenario after loss of power, if pilot lowers collective pitch quickly, he can autorotate and with sufficient altitude and with a suitable flat landing spot available, it's completely survivable and may save machine without damage.
  9. The Following 2 Users Say Thank You to albertq For This Useful Post:
    Frank S (Dec 26, 2024), nova_robotics (Dec 26, 2024)
  10. #7
    Jul 2018
    Flora, MS
    Floradawg's Tools
    I learn a lot from you. You have certainly been there and done that.
  11. The Following User Says Thank You to Floradawg For This Useful Post:
    Frank S (Dec 27, 2024)
  12. #8
    Supporting Member gatz's Avatar
    gatz's Tools
    Note the strap above at the beginning; dropped from above, perhaps from a Chinook
  13. #9
    Apr 2014
    Gadgeteer's Tools
    Did you fly?
  14. #10
    Quote Originally Posted by Gadgeteer View Post
    Did you fly?
    Only when a friend would take me up in his antique 47g trainer when I was briefly taking ground school.
