Results 1 to 10 of 11
Thread: A Drop-In Bench Vise Jaw Jack
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Sometimes I need to clamp a small piece of stock at one end of my bench vise. Without adding any packing to the other end, the jaws tilt resulting in poor clamping action. Adding packing of exactly the right thickness solves that problem. But I don't always have such packing. One solution is a variable thickness packing block or… a Jaw Jack.
    https://rick.sparber.org/DropInJawJack.pdf
    Thanks,
    Rick
    Rick
  2. The Following 5 Users Say Thank You to rgsparber For This Useful Post:
    Jon (Feb 21, 2020), Little Rabbit (Feb 20, 2020), oldpastit (Feb 21, 2020), verticalmurph (Feb 20, 2020), will52100 (Feb 20, 2020)
    Oct 2017
    pass ,,,too complicated and parts to loose,, how about a dozen 5/8 flat washers stacked on top of each other and loosely riveted or bolted together, at the far edge away from the center hole.. u just put how ever many washers u need to hold the gap open and u can run a thick wire or rod through center hole on top of vise jaws to keep washers in place while u hold other part and tighten vise..
  4. The Following User Says Thank You to madokie For This Useful Post:
    mklotz (Feb 21, 2020)
    Quote Originally Posted by madokie View Post
    Thank you for your post.
    Sometime ago I acquired more brass key tags than I will ever need and so decided to make an adjustable spacer with them...
    I've used it numerous times on my milling block...
    but, now, with the benefit of your post, I realize it would work perfectly as an adjustable vise shim.
  6. The Following 4 Users Say Thank You to mklotz For This Useful Post:
    bobs409 (Feb 23, 2020), jdurand (Feb 21, 2020), Jon (Feb 21, 2020), rgsparber (Feb 21, 2020)
    Oct 2017
    good ,,just what i was thinking ..
    Thanks mklotz! We've added your Adjustable Vise Shim to our Vises category,
    Thanks rgsparber! We've added your Adjustable Bench Vise Jaw Jack to our Vises category,
  10. #7
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    I realized from "madokie" and Marv's comments that I had not fully explained the purpose and how to use the jack. My goal is to have packing for the vise that prevents any tilting over a range of stock thicknesses. A stack of disks nicely solves the problem of getting close to a given thickness but, on average, will permit a tilt equal to 1/2 the thickness of a disk (assuming they are all the same thickness).
    The stack of packing plus the jack solves the problem. But since I don't have a stack of disks and am always looking for alternate ways to do anything, I made a stack of blocks with a binary ratio of thicknesses: 0.5", 0.25", 0.125", and 0.063". The jack takes up 0.375" to about 0.5". This means I can create any exact thickness from 0.375" to about 1.4" and never use more than 5 pieces.
    I'll update the article with proper acknowledgments.
    Thanks,
    Rick
    Rick
  11. #8
    You're absolutely correct about the stack permitting a slight tilt proportional to half the disk thickness. Fortunately the disks are thin and my aged vise is very sloppy.
    My compliments on having the insight to use a binary progression of spacers. I've been advocating that for a long time. As an example, DI extenders often come in a threesome of 1, 2, 3" sizes, which permits all the inch integer combinations up to 6"...
    1 = 1
    2 = 2
    3 = 3
    4 = 1 + 3
    5 = 2 + 3
    6 = 1 + 2 + 3
    but a binary threesome of 1, 2, 4" sizes permits all the combinations up to 7"
    1 = 1
    2 = 2
    3 = 1 + 2
    4 = 4
    5 = 1 + 4
    6 = 2 + 4
    7 = 1 + 2 + 4
    In a foursome of spacers, the difference becomes greater.
    1 + 2 + 3 + 4 = 10
    1 + 2 + 4 + 8 = 15
    and similarly for larger collections.
    Also, in binary collections with more members one has the advantage of simply writing the desired size in binary to determine which spacers to use.
  12. The Following User Says Thank You to mklotz For This Useful Post:
    Little Rabbit (Feb 24, 2020)
  13. #9
    Oct 2017
    exactly,, use a stack of washers with different thicknesses, to get your desired size, u can also use a short NF bolt(face off bolt head in lathe) and 2 nuts,run one nut (standard lenght or get a longer nut )to the end of bolt and use the second nut as a jam nut,u should be able to get your size easily within 010,, just use a magnet to hold bolt in place on vise..another way to do this is to drill and tap a hole all the way through vise and jaws and use a long bolt with a jam nut, a bit labor involved, but if your going to do this a lot..now if your going to be doing a lot of the same size parts , get a extra pair of small milling step jaw clamping height blocks and machine to size..or just make up some spacers to your needed size..
  14. The Following User Says Thank You to madokie For This Useful Post:
  15. #10
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    The design has not finished evolving. I found a box of old lock parts that were perfect for making a stack of equal thickness bars. I really like how the bars fill the gap between the fixed vise jaw and the jack. They naturally filled this gap by flopping down. Although it has a lot more parts, it is much easier to use without having to think much about it. The article has been updated with this iteration. Proof, again, that we should never throw any metal away. Also proof that all of us are smarter than any one of us.
    Rick
    Rick
  16. The Following User Says Thank You to rgsparber For This Useful Post:
