Results 1 to 9 of 9
Thread: Drip Irrigation: The Spaghetti Line to Hard Pipe Connection
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Spaghetti line is 1/4-inch in diameter and soft. The hard pipe I use is 1/2-inch diameter schedule 40 PVC. Typically, the hard pipe was previously buried in the ground. How do I connect a spaghetti line to the hard pipe at minimal cost and minimal effort?
    https://rick.sparber.org/SpaghettiLineHardPipe.pdf
    Thanks,
    Rick
    Rick
  2. The Following 4 Users Say Thank You to rgsparber For This Useful Post:
    Baddog (Jul 28, 2020), baja (Jul 29, 2020), Jon (Jul 30, 2020), willy13 (Jul 28, 2020)
    Baddog's Avatar
    Jun 2017
    Baddog's Tools
    I wonder if the heat of the ground will soften it enough to pop out?
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Quote Originally Posted by Baddog View Post
    Baddog,
    This type of connection is commercially available and has a proven track record. However, over time, the plasticizer will be driven out of the spaghetti line and it will become stiff. At that point, it will start to leak. However, I have a system that continuously monitors water use on a per zone basis. It will detect the when the flow increases by more than 30%. Then I will get an email. See https://rick.sparber.org/FMC.pdf for details.
    Rick
    Rick
    Rick is there not a solvent based adhesive which will react with both the spaghetti line as well as the PVC hard line? I know that poly urethane and poly vinyl chloride are incompatible so far as normal cementing is concerned
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    The spaghetti line must be periodically replaced when it gets hard. Gluing or welding it to the hard pipe would cause problems. All couplers I have seen either have barbs on the inside or squeeze the outside.
    Rick
    Rick
    Thanks rgsparber! We've added your Spaghetti Line to Hard Pipe Insertion Method to our Farm and Garden category,
  8. #7
    Rick
    It seems then that your solution would be much better than going with the quite expensive branch couplers given that you are going to have to replace the spaghetti line after a time anyway just pull the old one out and install a new one
  9. #8
    Baddog's Avatar
    Jun 2017
    Baddog's Tools
    Thanks Rick. You are far more energetic than I am!
  10. #9
    jdurand's Tools
    We've had more trouble from squirrels eating the line than age. The age shows up when we go to replace a piece and can't get it off the barb because it's hardened.
