Results 1 to 5 of 5
Thread: Drill press table clamps from scrap!
    Supporting Member EclecticNeophyte's Avatar
    Apr 2013
    TriCities, WA.
    EclecticNeophyte's Tools
    For your edification/consideration: Two scraps of angle steel, 5/15" bolts, nuts, washers.
    In the photo, the bits of angle are clamping down on an aluminum hub, that is having the center bore enlarged. I 'step drilled' this piece, and observed no movement while drilling it to 5/8" diameter...
    CAUTION: Drilling holes through angle steel can be hazardous to the health of you, observers or passers by, vehicles (i.e., wife's Mercedes), etc. Be VERY VERY CAREFUL!! :o
    -Vern
    Attached Thumbnails Attached Thumbnails Drill press table clamps from scrap!-drillpressclamps.jpg
  2. The Following 4 Users Say Thank You to EclecticNeophyte For This Useful Post:
    Jon (Dec 5, 2019), kbalch (Apr 29, 2013), lazarus (Jun 13, 2016), Paul Jones (Nov 12, 2015)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Vern! I've added your Drill Press Table Clamps to our Drilling and Drill Presses category, as well as to your builder page: EclecticNeophyte's Homemade Tools. Your receipt:
    Supporting Member Ed ke6bnl's Avatar
    Mar 2012
    So. California high desert
    Ed ke6bnl's Tools
    I like it start looking through my scrap and found some 1/2 x 3 in. stock that was scrap from an elevator shaft and just went and drilled several holes along the length for 1/2in carraige bolts and ground sides to fit the tee grove in my drill press and they worked fine for a cheapo x/y axis Harbor Freight vice I just picked up for $5. and your Idea worked great thanks ED
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    That's great!! Glad to hear that the clamp idea worked out for you.
    Ken
    Indiana
    Nice to see someone that has an idea that does not require massive amounts of time & materials. No damn bells and whistles. So simple that 99% of people do not think of it. Good Job!
