Results 1 to 7 of 7
Thread: Drill centered holes in round stock
    Jun 2020
    engineer steve's Tools
    An easy way to drill centered holes in round stock, I hope this inspires people or give some ideas.
  2. The Following User Says Thank You to engineer steve For This Useful Post:
    homey_g (Oct 15, 2020)
    Thanks engineer steve! We've added your Centered Hole Drilling Method to our Drilling and Drill Presses category,
    as well as to your builder page: engineer steve's Homemade Tools. Your receipt:
    Feb 2020
    Maybe it's the video angle but you show the end it was drilled from first (at 4:30)which is centred, then when it's turned around briefly to view exit end (at 4:35) the hole looks again to be off-centre.
    I'm not trying to criticise because it's a good idea, but that's how it looks.
    Last edited by tripleclown; Oct 20, 2020 at 08:18 AM. Reason: additional information
    Jun 2020
    @tripleclown the hole at 4:35 is off-centre indeed, but is it the hole I drilled in the beginning of the video to show how rubish drilling centered holes is without a jig/chuck. The hole I drilled with the chuck isn't a through-hole, I just didn't bother taking another piece of round stock :-)
    Supporting Member kess's Avatar
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    I thing you need to do something with your movable drill table.
    When you push to drill, then your table starts to bend downwards.
    Jun 2020
    @kess , you're right. It's a great little drill press (for the money) but the table is a bit disapointing. I am currently making a (very sturdy) milling table which will replace the table. (Video about the milling table can be found on my youtube-channel for when you're interested)
  8. #7
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    @engineer steve
    I have a similar drill press that had the same problems as all cheap drill presses when I bought it.
    I kept only the drill's head and replace the column and the base.
    You can see the conversion here at my HMT post if you interesting.
    Drill Press Modification
    Your DRO looks fine.
    Regards
