Results 1 to 8 of 8
Thread: Dremel modification. Light Edition!
    Supporting Member My MiniCrafts's Avatar
    Feb 2023
    My MiniCrafts's Tools
    Download plans for rotary tools.
  2. The Following 9 Users Say Thank You to My MiniCrafts For This Useful Post:
    Biggus1942 (Mar 1, 2023), Christophe Mineau (Mar 6, 2023), ductape (Feb 27, 2023), Jon (Mar 1, 2023), mklotz (Feb 27, 2023), rlm98253 (Feb 28, 2023), schuylergrace (Mar 1, 2023), Tule (Mar 1, 2023), uv8452 (Mar 1, 2023)
    Very nicely done, indeed. The secret to a tool that can be held and manipulated like a pencil is a high speed DC motor with the power source distanced from the tool; no batteries and an AC to DC converter in a wall wart with a light-weight, low drag cable to the tool.
    Dremel finally woke up and put together their model 2050...
    https://www.amazon.com/Dremel-2050-1...73&sr=8-2&th=1
    which embodies these design ideas but means buying yet another tool.
    The Dremel flexible shaft was never great and, like all flex shafts, interfered with fine control of the tool because of its stiffness. Folks who have that flex shaft should seriously consider converting it as you have done.
    Feb 2023
    Thank you. that was the point. I wanted a light and handy tool. I have three drmels and I have never used a flexible shaft as it is very uncomfortable. this is how the idea was born. Now I use it all the time. it is very convenient and easy
    Dec 2022
    Midwest US
    ductape's Tools
    This is an interesting and useful idea. Thank you for not putting obnoxious music in the video.
  6. The Following User Says Thank You to ductape For This Useful Post:
    Feb 2023
    I'm glad you like my modification. It's really convenient
    Thanks My MiniCrafts! We've added your Dremel External Motor Modification to our Rotary Tools category,
    as well as to your builder page: My MiniCrafts's Homemade Tools. Your receipt:
  9. #7
    Oct 2019
    Germany
    uv8452's Tools
    Dear Minicraft,
    I like the idea to convert my (unused) flexible shaft.
    Why not fit a switch into the hollow of the grip?
    BTW: The Dremel 'collets' have way too much play. If you have access to a lathe make some tight fitting ones.
  10. #8
    Feb 2023
    Thank you. I just didn’t have a small switch at hand, someday I’ll finalize it. As long as I am satisfied with the collets, I will use your idea if necessary. Thanks again
