Results 1 to 10 of 13
Thread: Double extended 15/16 socket
    The U bolts securing a headache rack to the frame of a semi truck are almost always a lot longer than needed with several inches of thread My deepest deep well impact socket was about 3 inches too short, so I made a special extended depth socket, by cutting one in half then welding a tube between the 2 pieces
    Double extended 15/16 socket-img_20220926_143010soc.jpg
    The ID of the tube was much larger than the OD of the socket
    Double extended 15/16 socket-img_20220926_143041soc.jpg
    To solve this I used my hose press to crimp the pieces together
    Double extended 15/16 socket-img_20220926_143132soc.jpg
    Double extended 15/16 socket-img_20220926_143215soc.jpg
    Double extended 15/16 socket-img_20220926_143408soc.jpg
    Double extended 15/16 socket-img_20220927_095255soc.jpg
  2. The Following 7 Users Say Thank You to Frank S For This Useful Post:
    baja (Sep 28, 2022), BuffaloJohn (Sep 28, 2022), Jon (Sep 28, 2022), KustomsbyKent (Sep 28, 2022), mr mikey (Sep 28, 2022), nova_robotics (Oct 4, 2022), Scotty1 (Sep 29, 2022)
    Supporting Member mr mikey's Avatar
    May 2022
    Michigan
    mr mikey's Tools
    When working on trucks, buses and equipment you always try to figure a way to make the job easier. One more trick up your sleeve when it works and the next time you do the same repair you're smiling. Good job. Mr Mikey.
    Quote Originally Posted by mr mikey View Post
    I have a set of pass through spline drive sockets but the largest stud which will pass through one of those is 1/2" probably why the set only goes up through 3/4"& 19 mm Its a nice set even has a 3" hollow extension, but nowhere near large enough for the ubolts
    I used to have a 15/16 Snap-on extended deep well impact socket that might have come close to being long enough but I haven\t seen it in probably 20 years.
    Reed mfg makes a really nice set of extended depth sockets but expect to pay over $300.00 for a set of 6 sockets ranging from 7/8 through 1 1/4"
    For that money I am perfectly happy to make my own as I need a different size
    Thanks Frank S! We've added your Extended Depth Socket to our Fastening category,
    Supporting Member Improvised DIY's Avatar
    Feb 2022
    Improvised DIY's Tools
    No chance here of the socket getting dislodged from the extension
    katy's Avatar
    Jul 2019
    Red Deer Alberta
    katy's Tools
    Heres one I made a number of years ago, a 9/16" socket, a piece of 3/8" pipe and a 1/2" bolt.
    Attached Thumbnails Attached Thumbnails Double extended 15/16 socket-extended-nine-sixteenths-socket.jpg
  8. The Following User Says Thank You to katy For This Useful Post:
    mr mikey (Sep 30, 2022)
  9. #7
    Quote Originally Posted by katy View Post
    looks like that would be handy for running nuts down on long threaded rods
  10. #8
    Thanks katy! We've added your Extended Socket to our Fastening category,
    as well as to your builder page: katy's Homemade Tools. Your receipt:
  11. #9
    katy's Avatar
    Jul 2019
    Red Deer Alberta
    katy's Tools
    It was made for removing the nuts off of long bolts holding a gas tank on. It didn't need to be that long, I just used a piece of pipe that I had, left it long instead of cutting it. It could always be shortened if needed.
  12. #10
    Congratulations Frank S - your Extended Depth Socket is the Homemade Tool of the Week!
    This is a helpful tool, and an especially clever use of a hose press.
    Cargo Box by Frank S
    Table Saw Anti-Kickback Device by Didpoolhall
    Cargo Box Mounting Structure by Frank S
    Piston Ring Cutter by Mr. Factotum's Workshop
    Pulley System by orioncons36
    Knife Sharpener by Mazay
    Machinist's Hammer by jbee
    Mortise Routing Jig by e_m_maker
    Frank S - you'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
    This is your 11th Homemade Tool of the Week. Here are all of your Homemade Tool of the Week winning tools. Congrats again
