Results 1 to 10 of 13
Thread: DIY Tormek Clone
    Supporting Member Sam's Workshop Diary's Avatar
    Jan 2019
    Sam's Workshop Diary's Tools
    DIY Tormek Clone
    I've build a Tormek clone out of scrap metal and a slicer motor.
    Here is Part 3. Now the jig for my chisels is working without water on my shoes. ��
  2. The Following 5 Users Say Thank You to Sam's Workshop Diary For This Useful Post:
    baja (Feb 13, 2019), PJs (Feb 13, 2019), Saxon Violence (Feb 14, 2019), Tonyg (Feb 13, 2019), Tule (Feb 13, 2019)
    Dec 2018
    Reverse rotation - might work better.
  4. The Following User Says Thank You to Nick79 For This Useful Post:
    Sam's Workshop Diary (Feb 13, 2019)
    Jan 2019
    Quote Originally Posted by Nick79 View Post
    Yes you are right, with a reverse rotation my jig would work. But now it's not so easy to change the rotation. I want to build another jig for the grinder, that will work with the excisting direction.
  6. The Following User Says Thank You to Sam's Workshop Diary For This Useful Post:
    PJs (Feb 13, 2019)
    Apr 2016
    Centurion, South Africa
    Nice build. One question - where is the wobble coming from on the wheels?
  8. The Following User Says Thank You to Tonyg For This Useful Post:
    PJs (Feb 13, 2019)
    Thanks Sam's Workshop Diary! We've added your Tool Sharpening Station to our Sharpening category,
    as well as to your builder page: Sam's Workshop Diary's Homemade Tools. Your receipt:
  10. #6
    Supporting Member high-side's Avatar
    Jun 2018
    Quote Originally Posted by Tonyg View Post
    Good job on the build.
    The wheels are simply mounted on a threaded rod. You could dress the wheels to get it to run more true.
    Question.. Is that a DC motor? Can you reverse the polarity to have it run either way?
    Pat
  11. #7
    My chisel grinder is commercial and runs 'forward'. Probably about same FPM, but smaller wheel. Its rest positions chisel more atop the periphery so lessens any tendency of fluid to run down an inclined chisel.
    Wet wheels aren't prone to burning edge of high carbon or HSS, so direction isn't too big a deal. Reverse though, will reduce wire edge to burnish flat.
    I add two drops of dishwashing soap [hand not machine] to the tray, that increases wetting and flush away grindings. Surely it would worsen drainage off inclined chisel.
  12. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    Sam's Workshop Diary (Feb 19, 2019)
  13. #8
    hemmjo's Tools
    How difficult would it be to just turn the motor assembly around to make the wheels run the other way?
  14. #9
    Jan 2019
    It comes from the threaded rod, it's crooked. Unhappily I don't have a lathe yet for better results.
  15. #10
    Jan 2019
    Quote Originally Posted by high-side View Post
    No it's an ac motor so I can't reverse the polarity. I have to change the motor coils and thats not easy at this motor.
