Hello,
I built a fan that will only blow air into a room when the temperature outside is lower than the temperature inside. Check it out and let me know what you think!
-Michael
Altair (Aug 11, 2019), JKeetonKnives (Aug 11, 2019), Jon (Aug 15, 2019)
Thanks m2rechtin! We've added your Temperature-Controlled Fan to our Heating and Cooling category,
as well as to your builder page: m2rechtin's Homemade Tools. Your receipt:
J. Keeton
"RedBeardOps" on both Youtube and Instagram
Youtube: https://www.youtube.com/redbeardops
Instagram: https://www.instagram.com/redbeardops/
If you ever need to do something like that tiny and cheap, you can use two silicon diodes (1N4148) as sensors along with an 8-pin comparator chip and two resistors. You probably need a transistor to help the comparator drive a DC fan directly or a relay for an AC fan. Won't give any readout but will switch fan on/off based on which sensor is hotter.
m2rechtin (Aug 12, 2019)
