Thread: DIY Static / Dynamic Water Pressure Gauge
    Supporting Member tsbrownie's Avatar
    Feb 2019
    tsbrownie's Tools
    DIY static / dynamic water pressure gauge. Allows comparison of pressure and flows. Good for diagnosing pressure / flow issues.
    MATERIALS
    - Water pressure gauge
    - Water filter tap (from home water filter) with valve (opening should be around 1/2 the **area** of the inside diameter of the flex tube)
    - Flex connection
    - Various adapters as needed to fit plumbing connections (spear, plastic tube, garden hose, etc.)
    - Thumbscrew band clamps
    - Adapters between things like gauge and 1/2 inch fittings depending on the outlet of the gauge you use.
    Re-edit.
  2. The Following 3 Users Say Thank You to tsbrownie For This Useful Post:
    Frank S (Mar 7, 2019), Papa Bill (Mar 14, 2019), saintrain (Apr 7, 2019)
    Thanks tsbrownie! We've added your Static and Dynamic Water Pressure Gauge to our Measuring and Marking category,
    as well as to your builder page: tsbrownie's Homemade Tools. Your receipt:
