Results 1 to 10 of 16
Thread: A DIY Secret to Easily Turn Screws On Your Lathe!
    Supporting Member AB-SHOP's Avatar
    Aug 2022
    Italy
    AB-SHOP's Tools
    Smile A DIY Secret to Easily Turn Screws On Your Lathe!
    Hi everyone,
    I think anyone who has ever had to modify existing screws without building them from solid, for example due to the excessive length, but also due to the size of the head: it happens that this must be less thick for example or with a smaller diameter.
    In this video I show you my version of a simple support with 2 screws, one inside the other, the smaller one acts as a block for the larger one, which being cut in half expands by opening (when the smaller one pushes) a few tenth by locking into place and pushing the screw to be modified.
    The screw to be modified is mounted frontally, on the thread side or on the head side depending on the modification to be performed!
    However, the force of the tool tends to tighten the screw, in favor of safety.
    Hope you like it!
    Alberto
    Attached Files Attached Files
  2. The Following 16 Users Say Thank You to AB-SHOP For This Useful Post:
    byates (Apr 7, 2023), cjfearn (Apr 13, 2023), Dimitris Polychronis (Jun 30, 2023), Jon (Apr 6, 2023), kess (Apr 7, 2023), lassab999 (Apr 17, 2023), Lockstocknbarrel (Apr 20, 2023), mr mikey (Apr 6, 2023), old_toolmaker (Apr 6, 2023), PaulsGarageProjects (Apr 9, 2023), piper184 (Apr 7, 2023), Scotty1 (Apr 7, 2023), sossol (Apr 6, 2023), soundguy (Apr 11, 2023), trevor_60_r (Apr 8, 2023), WmRMeyers (Apr 6, 2023)
    greenie's Avatar
    Dec 2018
    greenie's Tools
    To knock down the head of a bolt like that, --------- why not do it the real easy way
    Thread a nut onto the bolt and then shove the nut into the three jaw, then get at the head of the bolt with the tooltip.
    Saves wasting time making that "abortion", eh ? :-)
    Thanks AB-SHOP! We've added your Screw Turning Device to our Lathe Accessories category,
    as well as to your builder page: AB-SHOP's Homemade Tools. Your receipt:
  5. The Following User Says Thank You to DIYer For This Useful Post:
    Aug 2022
    Italy
    AB-SHOP's Tools
    Thank you for the definition of "abortion", it's the first time I've received such a kind compliment on one of my creations;
    what you wrote to me is correct and I already knew how to do it, but it certainly wouldn't run coaxial;
    I also wanted to create something different and functional, since you don't need spanner to lock the screw in position but only to rotate the 2 knurled parts by hands.
  7. The Following 8 Users Say Thank You to AB-SHOP For This Useful Post:
    cjfearn (Apr 13, 2023), Jon (Apr 6, 2023), Lockstocknbarrel (Apr 20, 2023), mklotz (Apr 6, 2023), old_toolmaker (Apr 6, 2023), Scotty1 (Apr 7, 2023), trevor_60_r (Apr 8, 2023), WmRMeyers (Apr 6, 2023)
    WmRMeyers's Avatar
    Dec 2014
    WmRMeyers's Tools
    Quote Originally Posted by greenie View Post
    Just because you don't see a need for such a device doesn't make it an "abortion."
    Bill
  9. The Following User Says Thank You to WmRMeyers For This Useful Post:
  10. #6
    WmRMeyers's Avatar
    Dec 2014
    WmRMeyers's Tools
    Quote Originally Posted by AB-SHOP View Post
    Not everyone needs a full-up lantern chuck, but for a lot of folks, putting the screw in a nut just doesn't give enough control. This is a good intermediate project for someone who wants to lightly customize some screws, but isn't looking at heavy production of complicated screws, or just making do. I like it enough to have download the drawings.
    Bill
  11. The Following 4 Users Say Thank You to WmRMeyers For This Useful Post:
    cjfearn (Apr 13, 2023), Lockstocknbarrel (Apr 20, 2023), old_toolmaker (Apr 6, 2023), piper184 (Apr 7, 2023)
  12. #7
    Feb 2015
    Prescott, AZ
    Shelly142's Tools
    Very clever device for the modification of screws and bolts. I also downloaded your excellent drawings.
    Phil
  13. #8
    Aug 2022
    Italy
    AB-SHOP's Tools
    Thanks Bill, i think so !!
  14. The Following User Says Thank You to AB-SHOP For This Useful Post:
    WmRMeyers (Apr 9, 2023)
  15. #9
    Aug 2022
    Italy
    AB-SHOP's Tools
    Hi Phil, happy that you liked my simple device and my drawings too; it is the first time that i upload the drawings, i will try to do the same in the future post !!
    A big ciao from Italy Phil,
    Alberto.
  16. #10
    piper184's Avatar
    Jul 2016
    piper184's Tools
    Nicely done.
    I like the idea of being able to work on either end from the same fixture. It gives the ability to hold any screw you have a tap for.
    Another project for my "to do" list
  17. The Following User Says Thank You to piper184 For This Useful Post:
