This is a table saw station that is compact and portable. The intent make the table saw can work maximum with large table top and also make it portable so it can be stored in a small area and moved to a larger space when ready to be used. I build this with HMR and combine with metal sheet aluminum on top table, that make really flat, smooth and low vibration also i set high with standard table saw cabinet 34 inches.
I made fence system lock with angel 26 degree/64 degre, this is make easy smooth, stabil and strong, why i not use 45 degree, if i use 45 degree more hard for move and not durable ans strong like 26 degree. i combine that with toggle clamp and extra addtional look on back fence for make stabil and strong
