Thread: DIY FastCap Clone Drill Index
    Supporting Member Downeast Thunder's Avatar
    Dec 2015
    usa
    Downeast Thunder's Tools
    FastCap makes many unique tools for wood workers and other craftsmen that simplify and speed up the job. The FastCap KISS™ Drill Bit Index is no exception.
    Being long on time, and short on money at the time, I decided to make my own version. It came out okay and works well, but the time and effort involved is not worth it (in my opinion), since it would be much easier, and more cost effective to simply call FastCap and order one already made.
    FREE PLANS!!!!!
    If you insist on making your own, I have prepared three drawings. The first one shows the dimensions. The second shows the arrangements of the laminations using “2-by” KD studs. The third drawing is simply a chart showing the arrangement and sizes of bits (which is the same arrangement FastCap uses). The drawings can be downloaded FREE in pdf format from my web page: Home • Paul Bennett's Downeast Thunder Creations
    Simply go to the Projects menu and pull up the “tools & equipment” category, then scroll to the drill index project and you will find the links for the download.
  2. The Following User Says Thank You to Downeast Thunder For This Useful Post:
    Seedtick (Nov 9, 2017)
    Thanks Downeast Thunder! We've added your Drill Bit Sorter to our Storage and Organization category,
    as well as to your builder page: Downeast Thunder's Homemade Tools. Your receipt:
