Results 1 to 1 of 1
Thread: DIY Easy, Low Cost Trash Bag Holder (From Scrap PVC)
    Supporting Member tsbrownie's Avatar
    Feb 2019
    tsbrownie's Tools
    An easy, cheap DIY trash bag, leaf bag holder. This one is 90% recycled PVC pipes.
    HOW TO SIZE
    It depends a lot on the size of bags you want to use.
    Height: I just measure the height of the bag and used 80%
    of that (takes pressure off the frame and allows for bag "expansion".)
    Depth: The 2 legs are 80% the depth of the bag from front to back.
    Width: The width is the width of the bag.
    MATERIALS
    - Pipe (I used recycled 1/2 inch PVC, 3/4 will also work)
    - Joints (type 1): 4x 3 way joints + 2x 90 degree joints (elbows)
    - Joints (type 2): 4x T joints + 6x 90 degree joints (elbows)
    OPTIONAL
    - If you want to clip the bag mouth open, you can use plastic pipe clips from your local hardware store. Either use as-is, or screw them to a "handle" from a piece of wood or plastic for easier handling.
