Thread: DIY Brilliant Circular Saw Guide Cut for left and right handed
    Supporting Member Didpoolhall's Avatar
    Feb 2019
    indonesia
    Didpoolhall's Tools
    A circular saw is a useful tool for breaking down plywood, but it can also be used to build impressive woodworking projects if you don't have a fancy shop or a lot of money. Here's everything you need to know about circular saws to get started.
  2. The Following 2 Users Say Thank You to Didpoolhall For This Useful Post:
    johncg (Mar 20, 2021), Tonyg (Mar 20, 2021)
    Aug 2016
    wizard69's Tools
    Interesting video but what is that green board? It doesn't look like PlyWood.
    Supporting Member Beserkleyboy's Avatar
    Aug 2014
    Beserkleyboy's Tools
    Wizard,
    It's MR MDF (Moisture Resistant MDF). A bit denser than std MDF, and highly moisture resistant. The green colour is added to the adhesive just to make it obvious that it is MR. Used extensively in 'wet area' situations in Aus, NZ and SE Asia, along with HMR Particle Board. Usually as a substrate for HPL and LPL laminates, veneers and painted finishes. One downside is that it still has ALL of the structural negatives of standard MDF...and, no, it is not waterproof or designed to be used externally...Cheers
    Jim - retired plywood and panel merchant in AUS
