You will also have to construct a way to drive 1 of the wheels making a bolt on hub or adapter for a pulley to be mounted on would be my suggestion but in order to prevent the stresses from breaking the center out of the wheel I would recommend the hub have at least 1 bearing in it.
Another option may be to fill the cavities between the spokes with an epoxy then mount the pulley directly to that with as large of a bolt circle as needed
