Results 1 to 10 of 15
Thread: Dividing Head (indexer) Version 2.0
    Supporting Member machining 4 all's Avatar
    May 2020
    machining 4 all's Tools
  2. The Following 9 Users Say Thank You to machining 4 all For This Useful Post:
    Big-Pete (May 19, 2020), Carnel (May 19, 2020), DakotaDave (May 18, 2020), FEM2008 (May 18, 2020), Jon (May 19, 2020), Karl_H (May 18, 2020), mwmkravchenko (May 18, 2020), Paul Jones (May 26, 2020), Saltfever (May 29, 2020)
    Thanks machining 4 all! We've added your Dividing Head to our Machining category,
    as well as to your builder page: machining 4 all's Homemade Tools. Your receipt:
    machining 4 all (May 31, 2020)
    Aug 2016
    wizard69's Tools
    Quote Originally Posted by machining 4 all View Post
    That is one nice looking indexer!
  6. The Following User Says Thank You to wizard69 For This Useful Post:
    May 2020
    Thanks for the comment!
    Sep 2019
    Hello.I am thinking of building some the same.
    What is the Torque (NM) of stepper motor you used
  9. The Following User Says Thank You to LeighS For This Useful Post:
  10. #6
    May 2020
    Hello LeighS! Below is a specification of the stepper motor used:
    - Nema 23 200 PPR
    - Holding torque: 9.8 kg.cm (0.9 N.m)
    - Rated current: 1.8 A
    - Recommended voltage: 24-48 V
  11. #7
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Very nice design and build. What are the specs for the two rear gears? Did you make these or sourced the gears from a supplier like Boston Gear?
  12. The Following User Says Thank You to Paul Jones For This Useful Post:
  13. #8
    May 2020
    Thanks for the comment Paul Jones! I made the gears myself. The larger gear has 84 teeth and the smaller gear has 21 teeth. I used a 1.25 mm metric module.
  14. The Following User Says Thank You to machining 4 all For This Useful Post:
    Paul Jones (May 28, 2020)
  15. #9
    Apr 2012
    NorCal
    Saltfever's Tools
    Very nice. Could you describe your bearings and how, of if, you preload them.
  16. The Following User Says Thank You to Saltfever For This Useful Post:
  17. #10
    May 2020
    Thanks for the comment Saltfever!The bearings used are 6006 2Z number. Preload equal to 37 N (3.8 kgf) carried out through the weight of the plate and the spindle (satisfactory value for a maximum rotation equal to 500 rpm).
  18. The Following User Says Thank You to machining 4 all For This Useful Post:
    Paul Jones (May 30, 2020)
