Digging a shallow well using a hand auger.
Utility cables hit by auger - photo
Skid-steer auger - GIF
Motorized ice auger spins out of control - GIF
Manufacturing augers in the 1990s - video
Auger forming machine - GIF
New plans added on 11/22: Click here for 2,593 plans for homemade tools.
johncg (Apr 26, 2022), mwmkravchenko (Apr 26, 2022), nova_robotics (May 4, 2022)
Been there... done that... twice. First was in Oregon. Helped an old neighbor turn the auger, but we didn't lift the dirt. We hooked a garden hose fitting on the upside of the T handle that had plugged ends. Hydraulics washed all of the loosened dirt up and out of the hole. Sure, it was a bit sloppy around the hole, but we were successful... we had our boots on. Hit water at 22', and went 3' more. Had a professional well crew come in to pump for reservoir. Neighbor watered a huge garden... never running out of water.
Second time was at the end of my backyard, a couple decades ago, four feet from the tiny creek that flows year-round. Stopped at 28'... never hit water or oil... damn! Clay all the way with a few rocks the size of a thumbnail, every now and then.
But it can sure be frustrating to dig a well, or anything of any depth in sand!!!.
I want to know how he turned the handle when he first started, and when he added the sections. He said the sections are 10 feet, that is a long way to reach up and be able to turn the auger.
I remember building a large deck for a client that was on a gravel area. Drilling for piers was a nightmare. In this area you need to go down 5 feet, It tool over an hour per pier with a powered one man auger. The kind you can rent on tow behind your vehicle wheels and is balanced from the big box stores.
So yes it is a terrible pain to try and get this done. I was close to using a larger sonotube ( concrete pier cardboard tube ) to act as a caisson. Just didn't have a larger one on hand that would have worked.
Maybe not drilled by hand, but the record for a hand dug hole stands at 240 meters, (790 feet).
At least that is what it says on the internet, so it must be true!!
