Results 1 to 5 of 5
Thread: DIFFERENTIATING ALUMINIUM BRONZE AND BERYLLIUM COPPER
    Mar 2018
    Rorschach's Tools
    As above, anyone know how to? Google has not been very helpful.
  2. #2
    philipUsesWood&Brass's Avatar
    May 2018
    Just a SWAG, but if they are the same size, I would think the aluminium bronze would weigh less.
    I think one would need Specific Gravity charts to get it Accurate.
    philip, In the Great Pacific NorthWET, where we had Intermitent Sunshine today, to confuse things.
    Mar 2018
    Rorschach's Tools
    Unfortunately I have no comparison piece.
  4. #4
    Quote Originally Posted by philipUsesWood&Brass View Post
    That's the ticket...
    Densities in gm/cm^3...
    Aluminum bronze - 7.45
    Beryllium copper - 8.25
    So cut two pieces with a volume on the order of a cm^3 and the weight difference, 0.8 gm, should be easily measurable on a small jeweler style scale. Small cylinders with a diameter of 1 cm and a length of 4/pi = 1.273 cm would have a volume of 1 cm^3. Of course, all that's really important is that the two samples have the same volume and that their weight difference, calculated from the data above, is large enough to register well on whatever scale is available.
  5. The Following User Says Thank You to mklotz For This Useful Post:
    philipUsesWood&Brass (Sep 18, 2018)
    This might not be of much help
    Alloy budhings.pdf
  7. The Following User Says Thank You to Frank S For This Useful Post:
