Thread: Die Nut Direction
    GeoffN's Avatar
    Apr 2017
    Ipswich,Qld
    Die Nut Direction
    Hi all, would like to throw one out there. When hand threading is there a correct side of a die nut to use, I was once told to start from the opposite side to the size branding. I have always used them this way, is there any truth to this or not.
    Regards
    Geoff
  2. #2
    Quote Originally Posted by GeoffN View Post
    Regards
    Geoff
    Most dies have a tapered lead-in section on one side. Closely examine a die for a larger size thread and you'll see that the lead-in on one side is different from that on the other.
    Start the die using the tapered lead-in.
    Don't trust the branding to determine which is the correct starting side. While it might work for certain makes of dies, I don't believe it's an established standard in the industry.
    BTW, if you're threading up to a shoulder first run the die in all the way having started from the tapered lead-in side, then reverse the die and chase up to the shoulder to provide a nearly completed thread.
  3. The Following 6 Users Say Thank You to mklotz For This Useful Post:
    Andyt (May 9, 2019), cmarlow (May 8, 2019), jackhoying (May 8, 2019), JTG (May 9, 2019), Moby Duck (May 9, 2019), Scotsman Hosie (May 8, 2019)
