Results 1 to 10 of 16
Thread: Die grinder attachment
    Jyväskylä Finland
    Tuomas's Tools
    Turning die grinder to dremel like multitool. - Part 1 -
    Making routing / shaping platform.
    Preview:
    Actual making:
    This Part also works as a base, for other attachments on the Part 2.
  2. The Following 11 Users Say Thank You to Tuomas For This Useful Post:
    blkadder (Oct 29, 2021), Chadboye (Oct 13, 2020), Chlor (Oct 11, 2020), high-side (Oct 20, 2020), jimfols (Oct 12, 2020), Jon (Oct 12, 2020), NortonDommi (Oct 11, 2020), rebuilder1954 (Oct 12, 2020), Sleykin (Oct 13, 2020), Tule (Oct 13, 2020), universal scale models (Oct 12, 2020)
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    Name of the tool in English is a router. Watching you grind steel is nothing short of amazing! A real artist.
    Jyväskylä Finland
    Tuomas's Tools
    Thanks.
    It has a drill chuck that allows to use bits with 2-8mm shank. And variable speed 2000- 14.000 rpm, that allows to use grinding, filing, sanding bits too.
    It can be used as a router, but its not just a router attachment. More like, shaping & routing platform / attachment?
    This was a Part 1. Kind of making the "base".
  5. The Following 2 Users Say Thank You to Tuomas For This Useful Post:
    blkadder (Oct 29, 2021), Sleykin (Oct 13, 2020)
    Jyväskylä Finland
    Tuomas's Tools
    Wip with the part two.
  7. The Following User Says Thank You to Tuomas For This Useful Post:
    Jyväskylä Finland
    Tuomas's Tools
    Just some finishing ( choosed to polish it ),
    And part 2 is done.
    Video comes later.
    Jyväskylä Finland
    Tuomas's Tools
    Finished belt sander attachment.
  10. #7
    Jyväskylä Finland
    Tuomas's Tools
    Preview:
    Video about making the part 2: Belt sander attachment
    This build is now ready.
  11. The Following User Says Thank You to Tuomas For This Useful Post:
  12. #8
    Thanks Tuomas! We've added your Router Sander and Linisher Attachment to our Metalworking category,
  13. #9
    Supporting Member high-side's Avatar
    Jun 2018
    You turn a palm router into a very versatile tool. Pretty amazing work!
    Pat
  14. #10
    Jyväskylä Finland
    Tuomas's Tools
    Thanks.
    But, like mentioned. Its actually a die grinder:
    https://tinyurl.com/yynhlery
    These are palm routers, or in Finland "edge routers": https://tinyurl.com/y2te572d
    Part 1 is about turning die grinder to palm router kind of tool.
    Part 2 uses casing made in Part 1 as an connection piece and Chuck guard.
  15. The Following User Says Thank You to Tuomas For This Useful Post:
