Demolished water tank flattens car.
Man survives inside car flattened by truck - GIF
Felled tree crushes truck - GIF
Crane boom crushes car - GIF
Haul truck crushes maintenance truck - GIF
Tractor runs over and crushes car - GIF
EnginePaul (Dec 8, 2022), mr mikey (Dec 7, 2022), Ralphxyz (Dec 7, 2022), that_other_guy (Dec 12, 2022)
Watched it frame by frame couldn't see anyone in the tower either, but did see some large bits of concrete dislodged and fall prior to the tower being pushed over.
by all of the graffiti on the tower, you could be right, that car could have been stripped in place, or if it happened to be a running vehicle the engine and hard parts were pushed into the softer ground beneath it, the car at the 44 second mark is clearly on harder surface since it is holding the tower off the ground slightly
