Results 1 to 1 of 1
Thread: DC-DC Converter, Input: 9 to 36 volts, Output: 24v
    Supporting Member tsbrownie's Avatar
    Feb 2019
    tsbrownie's Tools
    I thought you might find this interesting. It is an easy to use DC-DC converter that will take 9 to 36 volts input and output a steady 24 volt at 10 amps. They are commonly called buck converters or up / down converters. This one will take a high or low input voltage and output 24 volts.
    These come in different input ranges and output voltages. Great for DIY solar projects and supplying voltages for odd appliances.
    Warning: Electricity always carries the risk of burns, fire, shock, electrocution, etc. If you do not know, learn first or do not do it.
  2. The Following User Says Thank You to tsbrownie For This Useful Post:
    dubbby (Jun 22, 2020)
