Results 1 to 1 of 1
Thread: Cutting rads on a rotary table the easy way.
    Supporting Member Mook's Avatar
    Sep 2023
    Mook's Tools
    If you use a rotary table often it may be worthwhile to add a tenon on the base for a simple pre-trammed setup in the vise.
    Making a couple of precision tenons & clamps to use with a grinding vise makes setting the setting of radius centre points easy.
    Using the tool shank, a pin or even the spindle nose makes setting an endstop simple.
  2. The Following 3 Users Say Thank You to Mook For This Useful Post:
    Floradawg (Feb 27, 2024), Jon (Feb 29, 2024), nova_robotics (Feb 27, 2024)
