Andyt (Jun 15, 2022), asterix (Jan 20, 2023), baja (May 22, 2021), bensimmons (May 30, 2021), bigtrev8xl (May 24, 2021), BuffaloJohn (Jan 29, 2023), bustre (May 24, 2021), Carnel (May 22, 2021), CharlesWaugh (Jun 14, 2022), cindysdad (Sep 8, 2022), cognitdiss (Jan 21, 2023), Corm (May 24, 2021), davidschutt (Dec 6, 2024), DIYer (May 21, 2021), DIYSwede (May 23, 2021), elk-a-holic (May 21, 2021), EnginePaul (Jan 21, 2023), flyfr8rs (May 24, 2021), GedB (May 27, 2021), H.L (May 22, 2021), HobieDave (Jun 25, 2021), homey_g (May 31, 2021), Inner (May 21, 2021), johncg (May 30, 2021), johnreich (May 25, 2021), Jon (May 26, 2021), Moldyjim (May 24, 2021), mwmkravchenko (May 21, 2021), natie123 (May 21, 2021), NortonDommi (May 23, 2021), nova_robotics (May 22, 2021), ranald (May 29, 2021), raynjer (Jun 14, 2022), rdarrylb (Jan 21, 2023), RetiredFAE (May 21, 2021), rgsparber (May 23, 2021), rlm98253 (May 21, 2021), saguaro (May 27, 2021), Scotty1 (May 23, 2021), Skun Knuckles (Jun 1, 2021), Sleykin (May 22, 2021), tenncf (Aug 12, 2023), thehomeengineer (May 24, 2021), Thunderbelch (May 24, 2021), tmate3 (Jun 21, 2021), Tule (May 24, 2021)
Thanks bobneumann! We've added your Steel Plate Hole Cutting Method to our Metalworking category,
as well as to your builder page: bobneumann's Homemade Tools. Your receipt:
good vid,, i worked in the machine shop at a plant that made tilted gravel shaker units,we made the sides from 3/8-3/4 plate,, we clamped them together and tack welded them..then used starett hole saws ,, we never drilled a chip hole in the side,,most chips came out in long strings, we just pulled out the hole saw,an blew out any remaing chips and kept on sawing,,ran the radial arm drill press lowest it would go 60 RPM.. i think,,good vid but it ran over 10 min and u did not mention your RPM u ran at, so heres your Sam Kinison award,,,OOOOOH,OH,OOH,OOH,OOOOOH,OOH,OOH ,OOOOOH !!!!!
cognitdiss (Jan 21, 2023), EnginePaul (Jan 21, 2023), saguaro (May 27, 2021)
While I agree the tip has been around for a long time, it doesn't hurt to be reminded of useful tips from time to time either.
I also stand with previous comments about the importance of using low RPMs.
I will also add that using a lubricating coolant when ever feasible is equally as important as the low RPMs especially for increasing the longevity to the cutters.
As far as being brand agnostic goes we might as well be as probably many of the name brand cutters are most likely made by 2 or 3 manufactures and privately labeled
Having said that whenever possible I do prefer to buy hole saws with brand names after band saw blades instead of power tool names, which may or may not be any better or any different than the power tool names as well.
EnginePaul (Jan 21, 2023), NortonDommi (May 23, 2021)
EnginePaul (Jan 21, 2023), johnreich (May 25, 2021)
