Thread: Cutting gears - it's surprisingly easy
    Supporting Member Alans Home Workshop's Avatar
    Jan 2023
    Adelaide South Australia
    Alans Home Workshop's Tools
  2. The Following 7 Users Say Thank You to Alans Home Workshop For This Useful Post:
    EnginePaul (Feb 27, 2023), johncg (Mar 7, 2023), kboy0076 (Feb 28, 2023), nova_robotics (Mar 3, 2023), old_toolmaker (Mar 5, 2023), Scotty1 (Feb 25, 2023), uv8452 (Feb 27, 2023)
    Jul 2020
    Dialing in cutter depth each time just gives more chance for error. Turning the cutter over to conventional cutting feeding in from the end, then backing out past the end before indexing would eliminate that problem.
    Jan 2023
    Setting the cutter depth for each tooth was certainly a bit tedious However, doing it that way directed the cutting force towards the tailstock and ensured the (lightly gripped) work piece could not migrate into the chuck. I did use the method you suggest when cutting the 30 tooth gear and it is definitely a preferable way to work.
    Thanks for your comment.
