Results 1 to 10 of 10
Thread: Bench Seat for Bathroom Vanity Cabinet
    May 2014
    Del Mar, California
    Paul Jones's Tools
    I am not sure which forum category this project should be placed but I wanted to share the technique I used for constructing the seat legs.
    This is a custom bench seat I build in 2012 for one of our secondary bathrooms. The bathroom has a custom vanity cabinetry I built with a seat opening at the mirror. The seat was constructed from red oak that I custom milled on a table saw using a molding head cutter. The only wood part purchased was the oak rope molding. The wood joints are glued with aliphatic resin glue using either wood biscuits (openings cut with joint planner), pocket screws (and most of the pocket screw holes are covered with ¼” thick red oak), or ¼ X 20 threaded rod, nuts and washers.
    I think the most interesting parts of the project are the seat legs. The legs are constructed from various sections of oak with a 5/15” hole drilled through each center. The section with the fluted four-side pillar was constructed from three sections of ¾” red oak glued together and drilled down the center from both ends; cut into a square cross section, and fluted on my old Rockwell-Delta 9” table saw using a molding head cutter with three ¼” rounded-bottom flute cutters; and then sliced into sections on the miter saw. I used aliphatic resin glue (Titebond Original Wood Glue) on all the leg parts and then used the threaded rod to draw all the parts together while gluing and left in the leg. The legs are attached with pocket screws to the skirt under the top of the seat.
    Attached Thumbnails Attached Thumbnails Bench Seat for Bathroom Vanity Cabinet-constructing-vanity-seat-legs.jpg   Bench Seat for Bathroom Vanity Cabinet-stacked-parts-make-up-legs-bathroom-custom-bench-seat.jpg   Bench Seat for Bathroom Vanity Cabinet-secondary-bathroom-custom-vanity-bench-seat-closeup.jpg   Bench Seat for Bathroom Vanity Cabinet-secondary-bathroom-custom-vanity-bench-seat.jpg   Bench Seat for Bathroom Vanity Cabinet-custom-bathroom-vanity-bench-seat-ready-painting.jpg
    Bench Seat for Bathroom Vanity Cabinet-making-vanity-seat-leg-parts.jpg   Bench Seat for Bathroom Vanity Cabinet-pocket-screws-lower-rail-custom-bathroom-bench-seat.jpg   Bench Seat for Bathroom Vanity Cabinet-pocket-screws-wood-covering-custom-bathroom-bench-seat.jpg   Bench Seat for Bathroom Vanity Cabinet-pocket-screws-before-covering-custom-bathroom-bench-seat.jpg   Bench Seat for Bathroom Vanity Cabinet-corner-details-bathroom-custom-bench-seat.jpg
  2. The Following 6 Users Say Thank You to Paul Jones For This Useful Post:
    Captainleeward (Nov 22, 2015), DIYer (Nov 24, 2015), Jon (Nov 21, 2015), kbalch (Nov 23, 2015), PJs (Nov 24, 2015), Workshopshed (Nov 27, 2015)
    Classical and classy as well. Very nicely done.
  4. The Following User Says Thank You to mklotz For This Useful Post:
    Paul Jones (Nov 22, 2015)
    Just made the mistake of showing this to my wife.
    It's the integration of the same-height trim elements into the bench that we appreciate most. Less work to visually process the lines, and it aesthetically rewards the user for placing the bench properly back into its position.
  6. The Following 2 Users Say Thank You to Jon For This Useful Post:
    Paul Jones (Nov 23, 2015), PJs (Nov 24, 2015)
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Jon,
    How ironic because my wife is the one who asked me to build this matching seat bench. She wanted the seat to match the custom mill work I previously installed on the bathroom cabinets. We choose the classic off-white color because the shadows emphasize the lines of the mill work.
    Thanks for your architectural insight - much appreciated,
    Paul
  8. The Following User Says Thank You to Paul Jones For This Useful Post:
    PJs (Nov 24, 2015)
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    WOW Real Classy there Paul...:O)
  10. The Following User Says Thank You to Captainleeward For This Useful Post:
  11. #6
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Must not show to wife…
    Very nice work, indeed, Paul.
    Ken
  12. The Following User Says Thank You to kbalch For This Useful Post:
  13. #7
    Thanks Paul! We've added your Bench Seat to our Miscellaneous category, as well as to your builder page: Paul Jones' Homemade Tools. Your receipt:
  14. The Following User Says Thank You to DIYer For This Useful Post:
    Paul Jones (Nov 24, 2015)
  15. #8
    Supporting Member Catfish's Avatar
    Oct 2013
    Mariposa, California
    Catfish's Tools
    Nicely done Paul, a lot of thought went into this project. I am sure the seat is in the proper position always.
  16. #9
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Thanks Randy. Wood construction projects are my favorite homemade projects even though most people probably know me better by the machining projects posted here on HMT.
    I enjoy watching your YouTube channel. You should make a series about cabinetmaking next time you make more cabinets for your house. The ones you built are beautiful.
    Regards, Paul
  17. #10
    Sep 2018
    I have found this project through google. It's really impressive. Actually, it really great. I am willing to do similar woodwork project. But, I have little to no knowledge about this. This is my learning phase and your work really inspired me. Actually, I like this type of toilet.
