Crankshaft grinding machine.
Crankshaft journal polisher - GIF
Crankshaft grinding - video
CNC machining a crankshaft - GIF
CNC machining crankshaft journals - GIF
Casting crankshafts - GIF
nova_robotics (Aug 9, 2023), piper184 (Aug 10, 2023)
A long time ago I watched a small automotive machine shop setup and grind a crank. It did not have the follower. The operator had to dial in each set of journals. Once everything was running true, the grinding wheel was moved from journal to journal. I think he did the mains first, then the offsets for the pistons. It would take a day or more to get a crank turned back then.
nova_robotics (Aug 10, 2023)
