Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Crane lifts shipping container stuck to trailer - GIF
    Supporting Member Fluffle-Valve's Avatar
    Oct 2015
    Duston, Northampton, UK
    I used to do this sort of work driving in and out of Felixstowe, UK.
    Even though the pins are in the open position, they still get caught and can lift the trailer.
    I have a 1972 Land Rover Series III Truck Cab/Pick-Up and a 1962 Land Rover Series 2a Carawagon Camper.
  2. #12
    Quote Originally Posted by Fluffle-Valve View Post
    More's the reason for having drop down locks they are spring loaded and any jostling once they are released should cause them to retract but a good rap with a hammer is never a bad idea before the container is raised or raise it a few inches and set it back down then lift it off the trailer. I've seen crane operators have to bounce a container a few times make them come loose
  3. The Following User Says Thank You to Frank S For This Useful Post:
    Fluffle-Valve (Jul 8, 2022)
