Results 1 to 10 of 12
Thread: Countersink Inside a tube
    Apr 2017
    UK
    editor@glue-it.com's Tools
    I needed to countersink a hole inside the case of a model engine so that I could fit a bracket. The only way I could think of doing it was to make an extension for the countersink with a small drive shaft - by default the countersink head is bigger in diameter than the hole it is countersinking. Even with holes opposite each other this would be a difficult problem to solve.
    in action
    or nearly in action as I ended up driving it with a small hadnheld electric drill.
  2. The Following 13 Users Say Thank You to editor@glue-it.com For This Useful Post:
    baja (Apr 7, 2020), bruce.desertrat (Apr 7, 2020), HobieDave (Apr 5, 2020), HUMARIA (Apr 7, 2020), jackhoying (Apr 6, 2020), Jon (Apr 6, 2020), mklotz (Apr 5, 2020), Okapi (Apr 7, 2020), olderdan (Apr 5, 2020), Paul Jones (Apr 6, 2020), rgsparber (Apr 5, 2020), Toolmaker51 (Aug 28, 2022), Tule (Apr 7, 2020)
    There are tools made to countersink the otherwise inaccessible back side of a hole but such tools would have been expensive overkill for your problem.
    Your solution of constructing the needed tool inside the obstruction is an ingenious technique that should be in everyone's mental quiver of unusual solutions. Good on you.
  4. The Following 3 Users Say Thank You to mklotz For This Useful Post:
    baja (Apr 7, 2020), Paul Jones (Apr 6, 2020), Toolmaker51 (Aug 28, 2022)
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    I wonder if this could be done with something like the mechanism used in expanding anchors. Slide the tool into the hole, turn a screw to expand the end, and then back out as the reverse countersink is cut. Then turn the screw the other way to collapse the cutter and retract the tool. Not a lot of room for the mechanism.
    As long as we are cutting AL, it could be made from mild steel. Beyond that, use oil or water hardened drill rod.
    Rick
    Rick
    Rick
    Most of the commercial tools I've seen pictured do essentially what you suggest. Actually, I think the physics of the situation demand that sort of solution. But, as I said, they would be expensive overkill if you have some access to the backside of the hole as was the case with the OP.
    Another possible technique is a cutter with an inverted cone shape, i.e., the cutting end flares outward from the shaft at the tip, major diameter at the very end of the tool (picture a router dovetail bit, only much smaller). If the diameter of the cutter is small enough to pass through the hole and the angle of the cone matches the required countersink angle, then insert tool through hole and move around in small circle to cut the countersink. Recenter to withdraw from hole.
    The geometry works but I sure wouldn't want to be the guy tasked to make it work in practice.
    Apr 2017
    UK
    Thanks, the thing is when you need a tool like this you need it fairly urgently and hence making it was a good option
    Cheers, Nigel
  9. #7
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Just a thought experiment - picture a countersink with the shank coming out the end where the point normally is. Slip in from the back side, chuck into your drill, and pull as it turns.
    Rick
    Rick
  10. #8
    Thanks editor@glue-it.com! We've added your Countersink Extension to our Fastening category,
    as well as to your builder page: editor@glue-it.com's Homemade Tools. Your receipt:
  11. #9
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    I see countersinks that slide over a drill bit so you can drill the hole and countersink in one operation. Replace the drill bit with a rod and you have a “reverse countersink “. Feed the tool in from the back side, chuck the rod in a drill, pull trigger while pulling away from the surface.
    Rick
  12. #10
    Apr 2017
    UK
    Anybody fancy building and sharing some of the different countersink options?
