Results 1 to 5 of 5
Thread: Converting a Certiflat plasma table into a CNC plamsa table!
    Haslip Cycle Works's Avatar
    Haslip Cycle Works's Tools
    This will be a multi part build. The goal is to build a CNC plasma table using my Certiflat plasma table as a base. This will be a budget build, so no auto torch height control or any other fancy bits. I also want to make it modular incase I want to upgrade to a bigger table, so as much as possible will be bolt on. This is my first venture down this road, so fingers crossed.
  2. The Following User Says Thank You to Haslip Cycle Works For This Useful Post:
    Jon (Mar 19, 2020)
    Supporting Member gatz's Avatar
    gatz's Tools
    good start
    I don't see any more vids on YouTube for this; will you be posting the next Parts here ?
    Quote Originally Posted by gatz View Post
    good start
    Thank you!
    I usually only post videos once a week. Every Sunday at 5PM EST.
    I will post links to the videos here as they come out.
    Rikk's Avatar
    Nov 2018
    Rikk's Tools
    Following this. Once you have everything hammered out, could you post a parts list as well?
    Cheers!
    gatz's Tools
    OK, thanks.
