Results 1 to 7 of 7
Thread: Continuous chips from milling an aluminum block - GIF
    Continuous chips from milling an aluminum block.
    Milling a part with a lollipop end mill - GIF
    Sinusoidal milling - GIF
    Hot plunge milling - GIF
    Two-spindle 5-axis CNC mill - GIF
    CNC milling a stainless steel part - GIF
    johncg (Jun 4, 2023), nova_robotics (Jun 3, 2023), that_other_guy (Jun 3, 2023)
    Sep 2015
    Kansas
    That looks like steel to me. Notice the rust on the left end.
    WmRMeyers's Avatar
    Dec 2014
    WmRMeyers's Tools
    Sure does.
    Sep 2018
    nova_robotics's Tools
    Could be, but the chips look like aluminum to me. Pushing a mill that hard with no coolant will cause steel chips to come off golden, blue or even red hot. Aluminum stays silver in appearance. It's a bit hard to judge scale, but to me that looks like a 1/2" - 3/4" end mill. That depth of cut and that speed would be very high for steel.
    Edit: Yeah nevermind I think it's steel.
    If it is steel then it is probably 12 or 14L
    12L14's Avatar
    Aug 2017
    12L14's Tools
    Will try answer as best as I can.
    Imagine climb* and slab milling at once, but done with a short VHM endmill(or really stubby HSS one).
    You need to sacrifice stepover for that depth of cut, but at the same time it is possible to get much higher Vc(heat isn't concentrating at endmill tip - but is spread more evenly, same goes for wear) and you NEED TO bump up feed drastically(to avoid so called chip thinning - with proper Vc and chip cross section there is no need for coolant, as 90%+ of machining heat goes to swarf).
    Good writeup at harwiperformance(Helical over here):
    https://www.harveyperformance.com/in...iency-milling/
    https://www.basstool.com/pdf/promos/HEM_Guidebook.pdf
    and video from Gühring:
    Tomorrow I can try to write something about minuses of that milling technique(unfortunately there are many downsides).
    *conventional is possible - but I'm avoiding it(except for „springback pass” in some materials).
  8. The Following 4 Users Say Thank You to 12L14 For This Useful Post:
    ductape (Jun 4, 2023), Inner (Jun 6, 2023), nova_robotics (Jun 4, 2023), Scotsman Hosie (Jun 11, 2023)
  9. #7
    Sep 2018
    Hey I own a Chiron! It's awful!
  10. The Following User Says Thank You to nova_robotics For This Useful Post:
    Frank S (Jun 4, 2023)
