Results 1 to 1 of 1
Thread: Compound-planet split-ring planetary gearset
    Supporting Member TilenThaler's Avatar
    Mar 2019
    TilenThaler's Tools
    A compact planetary gearset, capable of relatively high gear ratios. The one before you has a ratio of approximately -18.06:1, which means, that turning the sun gear 18.06 times, will result in one outer ring turn in the opposite direction.
    A great tool to study the advanced planetary gear systems and a very useful system in many applications, like valve actuators, robot arms and many others, where high gear ratios are desirable in a small package.
  2. The Following 4 Users Say Thank You to TilenThaler For This Useful Post:
    Altair (May 22, 2020), Jon (Mar 26, 2020), Saltfever (Mar 23, 2020), walgui (Mar 27, 2020)
