Results 1 to 4 of 4
Thread: Compound drill shop project
    Supporting Member shopandmath's Avatar
    Jun 2019
    Kitchener ON,CA,
    shopandmath's Tools
    with this video I show how to do the calculations for a compound angle for drilling
    using dimensions distance from top hole and bottom hole and height of block
    Video link
  2. The Following 2 Users Say Thank You to shopandmath For This Useful Post:
    marksbug (Dec 11, 2019), metric_taper (Dec 18, 2019)
    Apr 2016
    I need to do some compound milling and drilling,Ill give this a good going over when Im ready to do it I just hope I can comprehend it....my brain aint all it used to be and memory is almost gone. I hope to get started on it by next summer...I hope. changeing angles of valve guides & seats in some of my new cylinder heads along with totaly reworking the valvetrain system with totaly massivly different parts. ( aircooled vw stuff getting nascar upgrades) years ago it would of been eazy, nowdays...not so much ,it's a good thing I have 5 new castings to work with.one to get it all right&figured. still have lots of welding to get done on them first. thanks for the post!!! I hope I can figure it all out.
  4. The Following User Says Thank You to marksbug For This Useful Post:
    shopandmath (Dec 13, 2019)
    Jun 2019
    Kitchener ON,CA,
    shopandmath's Tools
    Thank you for your comments
    Ray
    Marion, Iowa
    metric_taper's Tools
    Ray, does your shop have a compound sine plate? I picked one up a few years ago, it seems it would be used differently, then your example here where the 2nd axis is rotated but at the angle of the base sine plate. Am I wrong in this thinking?
