Results 1 to 10 of 11
Thread: Coal power plant explosion in Pakistan - GIF
    nova_robotics (Apr 16, 2022), Rangi (Apr 29, 2022), rlm98253 (Apr 13, 2022)
    Sep 2013
    Karl_H's Tools
    Cool how the flame goes right down the conveyer path. I suspect it was mostly dust that blew up.
    Mar 2015
    What are the chances that a video photographer would have that perfectly framed in his camera at the instant of explosion unless it was a planned demolition and not an accident? Motion prior to the explosion indicates it was hand-held. The yard looks in disarray as if during dismantling and the building n the foreground is stripped with cranes overhead..
  5. The Following User Says Thank You to awright For This Useful Post:
    rebuilder1954 (Apr 13, 2022)
    Supporting Member bob_3000's Avatar
    Aug 2020
    It is a video someone took of a screen playing security camera footage, not the original recording.
    Supporting Member schuylergrace's Avatar
    Sep 2020
    Mesa, Arizona
    Another interesting thing is that nobody on the ground seems terribly fazed by the explosion. So, I don't think it was terribly unexpected. Maybe, it's a semi-regular occurrence? Maybe, it was demo. I can't tell by the obvious con/destruction work going on, but they may have been adding onto the plant and/or demolishing (or trying to demolish, since it seems little worse for the wear after the explosion) part of it. But I don't think this is a shot of a security monitor. It appears to be just somebody looking over the construction site.
    For topical application, only. Not to be taken internally or used in com-
    bination with other drugs or alcohol, except as directed by your shaman.
    Do not operate heavy equipment, unless you actually know how to.
    Mar 2015
    I presume bob_3000 is concluding that from the frame one sees at the left in the initial stages of the video. That does not appear to me to be a view of a video display screen. It looks like a view out of a window. Note that there is blue sky and a glimpse of the continuation of the building in the foreground to the left of the frame seen at the left for a short time. Also, videos of video displays normally show anomalies due to slight lack of perfect synchronization between a line-powered display and a battery-powered recording camera. We see none.
  9. #7
    Supporting Member Fluffle-Valve's Avatar
    Oct 2015
    Duston, Northampton, UK
    I have a 1972 Land Rover Series III Truck Cab/Pick-Up and a 1962 Land Rover Series 2a Carawagon Camper.
  10. The Following 2 Users Say Thank You to Fluffle-Valve For This Useful Post:
    nova_robotics (Apr 16, 2022), schuylergrace (Apr 14, 2022)
  11. #8
    Mar 2015
    Well, I have to yield to fluffle-valve's documentation that it was, in fact, an accident. But I'm still mystified that someone was positioned with perfect timing to videotape the event. Not even having to whirl around to capture the event while taping the general area, but perfectly framed before it started. What luck for a cameraman.
  12. The Following User Says Thank You to awright For This Useful Post:
    Fluffle-Valve (Apr 14, 2022)
  13. #9
    Oct 2015
    Quote Originally Posted by awright View Post
    I too thought it was a planned explosion at first and hence the reason I did a little research. But, I guess, some people just get lucky with the video camera.
  14. #10
    Mar 2018
    Looks like they need to update their cleaning PMs to more frequent cleaning. I thought they misted those areas to prevent the dust?
    "This country was founded by a bunch of slave owners that told us all men are created equal..." - George Carlin
