Coal power plant explosion in Sindh, Pakistan.
Coal conveyor fire - GIF
PEPCON chemical plant explosion - GIF
Beverage plant explosion - GIF
Automated coal train car sprayer - GIF
New plans added on 11/15: Click here for 2,581 plans for homemade tools.
nova_robotics (Apr 16, 2022), Rangi (Apr 29, 2022), rlm98253 (Apr 13, 2022)
What are the chances that a video photographer would have that perfectly framed in his camera at the instant of explosion unless it was a planned demolition and not an accident? Motion prior to the explosion indicates it was hand-held. The yard looks in disarray as if during dismantling and the building n the foreground is stripped with cranes overhead..
rebuilder1954 (Apr 13, 2022)
Another interesting thing is that nobody on the ground seems terribly fazed by the explosion. So, I don't think it was terribly unexpected. Maybe, it's a semi-regular occurrence? Maybe, it was demo. I can't tell by the obvious con/destruction work going on, but they may have been adding onto the plant and/or demolishing (or trying to demolish, since it seems little worse for the wear after the explosion) part of it. But I don't think this is a shot of a security monitor. It appears to be just somebody looking over the construction site.
For topical application, only. Not to be taken internally or used in com-
bination with other drugs or alcohol, except as directed by your shaman.
Do not operate heavy equipment, unless you actually know how to.
I presume bob_3000 is concluding that from the frame one sees at the left in the initial stages of the video. That does not appear to me to be a view of a video display screen. It looks like a view out of a window. Note that there is blue sky and a glimpse of the continuation of the building in the foreground to the left of the frame seen at the left for a short time. Also, videos of video displays normally show anomalies due to slight lack of perfect synchronization between a line-powered display and a battery-powered recording camera. We see none.
I have a 1972 Land Rover Series III Truck Cab/Pick-Up and a 1962 Land Rover Series 2a Carawagon Camper.
nova_robotics (Apr 16, 2022), schuylergrace (Apr 14, 2022)
Well, I have to yield to fluffle-valve's documentation that it was, in fact, an accident. But I'm still mystified that someone was positioned with perfect timing to videotape the event. Not even having to whirl around to capture the event while taping the general area, but perfectly framed before it started. What luck for a cameraman.
Fluffle-Valve (Apr 14, 2022)
