Results 1 to 10 of 10
Thread: Cleaning Precision Measuring Tools
    jmayaa's Avatar
    Mar 2015
    Hagerstown, MD
    I recently picked up some used dividers of different styles along with some micrometers.
    The calipers are pretty much coated with a surface rust or really tarnished. The micrometers have a few spots of rust here and there and the insides are really dirty.
    I was thinking of using Evaporust, but am concerned it may be to harsh for the mics. They have the satin type finish.
    Just wondering what techniques you all have used to derust/clean your precision tools.
    Thanks,
    Jeff
  2. The Following User Says Thank You to jmayaa For This Useful Post:
    Paul Jones (May 3, 2015)
    Following this thread, as I've got a stuck micrometer that would be useful if I got to free it up.
    Mar 2015
    I use Evaporust All the time,it won't hurt your tools. Go to bob cartwright on utube. I have two videos on rust removal with Evaporust.
  5. The Following 2 Users Say Thank You to big fall Bob For This Useful Post:
    Jon (Mar 10, 2015), Paul Jones (Mar 17, 2016)
    Thanks for the tips, Bob. Gonna look up your videos.
    Quote Originally Posted by big fall Bob View Post
    Nice Youtube channel . Feel free to embed Youtube videos using the icon that looks like a filmstrip, or manually like this:
    HTML Code:
    [video=youtube;l8G8i3XwMxA]https://www.youtube.com/watch?v=l8G8i3XwMxA[/video]
    Here are the Evaporust videos:
  8. The Following 4 Users Say Thank You to Jon For This Useful Post:
    DIYer (Mar 11, 2015), Hotz (Mar 11, 2015), Paul Jones (Apr 29, 2015), PJs (Apr 6, 2016)
    Supporting Member crazypj's Avatar
    Nov 2014
    Central Florida
    crazypj's Tools
    I usually dunk things in 'gas pump' diesel. It has all sorts of preservatives and cleaners so works pretty well.
  10. The Following User Says Thank You to crazypj For This Useful Post:
    DIYer (Apr 29, 2015)
  11. #7
    Doc
    Doc is offline
    Supporting Member Doc's Avatar
    May 2013
    Doc's Tools
    I use household vinegar or a solution of citric acid (from the grocers). Wipe on wet or soak the tool (depending on it's 'internals'). Leave for a few minute then wipe off. Rinse and repeat. Dry then wipe with your favourite oil or dry lube stuff.
    Regards
    Doc
  12. #8
    Thanks for the additional tips guys. I use diesel to clean my bicycle chain (and leave it on for a ride or two before using lube), but it never occurred to me to try using it for stuck parts.
  13. #9
    Nov 2014
    Polson MT summer Seattle WA winter
    Check out electrolysis. This source is practical and concise. Be sure to read, understand and follow this and wear these -safety glasses.
    Rust Removal using Electrolysis
    John MTO
  14. The Following User Says Thank You to JohnMTO For This Useful Post:
  15. #10
    Kroil is the best of the commercially available penetrating oils. A shade-tree substitute is a 50-50 mix of ATF and acetone. Be careful with the latter around plastics. Some plastics will mark with acetone.
    Warm the mike gently, eg with a light bulb, to get better penetration.
    For light surface rust a fine Cratex stick works well. I've also had some success with Simichrome polish but only for very light rust.
  16. The Following 2 Users Say Thank You to mklotz For This Useful Post:
    Paul Jones (Mar 17, 2016), PJs (Apr 6, 2016)
