Results 1 to 6 of 6
Thread: Circular saw to chop saw conversion..
    Jyväskylä Finland
    Tuomas's Tools
    This is my simple stand for the circular saw, that turns it to the chop saw.
    I used cheap 110mm = 4 " 9 ( 29 € ) circular saw.
    I wanted to cut metals with it, ones with the thin wall.
    For that reason i used 125mm = 5 " diamond angle grinder blade instead of teethed blade.
    Teethed blade is maybe little faster, but when material is thin ( 2mm or less ) it tends to rip edges, very thin material may also bend.
    To be able to use bigger blade i removed the lower guard from the saw.
    I know one might think that its very dangerous now, but actually it still has somewhat similar guard than angle grinder has.
    So, if i don't mess around, its perfectly safe.
    Hinge is made from the bigger weldable hinge, i shared one part from it to two.
    Cost for the hinge ( including axle and washers ) was 8€
    I weld a washer to the end of the axle, and sanded weld to the surface level.
    Axle is weld to second cylinder piece from the outer end. Then only one cylinder part is moving.
    Frame is made from 20 mm x 20 mm x 3 mm angle iron.
  2. The Following 4 Users Say Thank You to Tuomas For This Useful Post:
    Jon (Oct 23, 2019), PowerMk (Oct 21, 2019), rossbotics (Oct 19, 2019), Tule (Oct 19, 2019)
    Thanks Tuomas! We've added your Chop Saw to our Metalworking category,
    Jyväskylä Finland
    Tuomas's Tools
    Testing bigger version.
    Video about making comes later.
  5. The Following 2 Users Say Thank You to Tuomas For This Useful Post:
    Jon (Oct 21, 2019), PowerMk (Oct 21, 2019)
    Supporting Member PowerMk's Avatar
    Mar 2019
    PowerMk's Tools
    Hello Tuomas where are you? Whats happened with your channel? I see you have a new channel and you have stop to upload on your old.
    I m waiting for full version video its looks very interesting!
    Jyväskylä Finland
    Tuomas's Tools
    Quote Originally Posted by PowerMk View Post
    I decided to keep little break.
    New channel is for this kind of short clips. I will upload full videos to my main channel. Soon i hope.
    Jyväskylä Finland
    Tuomas's Tools
    Here is the finished cutter.
  9. The Following 2 Users Say Thank You to Tuomas For This Useful Post:
    bruce.desertrat (Oct 23, 2019), PowerMk (Oct 23, 2019)
