Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: Circuits to reuse washing machine motors to drive workshop tools
    Supporting Member Bongodrummer's Avatar
    Dec 2013
    Wales
    Bongodrummer's Tools
    The 3/4 horse power universal motors used in washing machines are an abundant source of power for all kinds of workshop tools, from a small lathe to a disc sander The problem is we can't just hook them up to their rated voltage without some kind of control circuit. At no-load speeds the motor goes so fast it damages itself.
    In the past I have used a few different control circuits to control these motors. The most recent is used in the multi purpose rotary tool I have been making http://machine.construction/rotary_tool In this I use a closed loop Arduino based circuit that uses a PID algorithm to try and match your desired set speed, with the actual measured rpm of the washing machine motor. This was a relatively complicated circuit, and in the video I show how to make it and compare it to the more simple triac based circuits.
    Bongodrummer
    Subscribe to my Youtube Channel
    FloweringElbow.org Blog
    Flowering Elbow on Facebook
  2. The Following 29 Users Say Thank You to Bongodrummer For This Useful Post:
    12L14 (Jul 31, 2019), baja (Jun 3, 2019), Bverysharp (Jun 8, 2019), Christophe Mineau (Feb 1, 2020), cognitdiss (Apr 13, 2024), davesrepair (Apr 9, 2024), Duke_of_URL (Oct 3, 2023), EnginePaul (Jun 3, 2019), frakenasty (Aug 17, 2021), Home-PC (Jul 23, 2021), Jon (Jun 3, 2019), JTC (Jul 12, 2019), kboy0076 (Mar 12, 2023), labhras773 (Sep 5, 2020), lassab999 (Jul 24, 2021), Little Rabbit (Aug 17, 2023), MeJasonT (Jun 4, 2019), Moby Duck (Aug 4, 2023), mwmkravchenko (Jul 24, 2021), NortonDommi (Jun 8, 2019), Ralphxyz (Oct 7, 2023), Raytonian (Jun 12, 2019), rlm98253 (Mar 7, 2023), Sam's Workshop Diary (Jun 4, 2019), Scotsman Hosie (Jun 11, 2019), Tonyg (Oct 4, 2023), totaltool (Jul 24, 2021), Tuomas (Jun 4, 2019), volodar (Jun 6, 2019)
    jdurand's Tools
    My washing machine (LG brand) has a multi-phase motor with the armature bolted right to the drum (no belts or gears). I think it's driven as a stepper from the sound and the low speed torque.
    Be an interesting motor to salvage for things like rotary tables. I wonder if the drive electronics are separable from the processor?
    Dec 2013
    Wales
    That is really interesting. Sounds like it would make a reasonable motor for some kind of CNC application if you could untangle it from the drum, and get a handle on the control board?
    Bongodrummer
    jdurand's Tools
    At the moment it's doing our laundry, so I may have to wait a while for spousal approval of an autopsy.
  6. The Following 3 Users Say Thank You to jdurand For This Useful Post:
    davesrepair (Apr 9, 2024), Duke_of_URL (Oct 3, 2023), Toolmaker51 (Jun 3, 2019)
    Thanks bongodrummer! We've added your Electric Motor Control Circuit to our Electronics category,
    as well as to your builder page: bongodrummer's Homemade Tools. Your receipt:
    Yep. A motordectomy is sure to be noticed.
  9. #7
    jdurand's Tools
    I found a picture of the motor from a repair parts place
    link to the repair place
    https://www.huoltopalvelu.com/LG-was...ct-drive-motor
  10. The Following User Says Thank You to jdurand For This Useful Post:
  11. #8
    jdurand's Tools
    Looks like it's only 3 phase so they're using a VFD to drive it.
  12. #9
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Hi, thanks a lot for that very clear video, this is really valuable stuff, and I think you are one of the first across the World Wide Web to fully document and explain the close loop circuit.
    Driving a washing machine motor is one of the most massive technical meme and one could read hundreds of forum pages dealing with this question, (and I have read many of them).
    There are only a few solutions that can be workable with universal motors, and most of the time, the proposed solutions keep open loop and cannot offer a proper regulated speed control. For closed loop solution, the principle is often explained, but no practical solution is ever showed, except this guy, you probably visited his page, who makes home brewery, and started an equivalent project, but I don't think his page is as well documented and explained as yours.
    Just to mention that there is also an alternative using a tda1085 circuit, there is a Russian guy selling the PCB on eBay, even a wired version, but it's not as easy and maybe there is a parametering issue as you mentioned at the end.
    So , congratulations and many thanks for this so valuable post ! And keep posting!
    Cheers,
    Christophe
  13. #10
    Dec 2013
    Wales
    Hi Christophe. I really appreciate the encouragement, thanks!
    As you say it is quite the technical challenge to do closed loop control on a universal motor, and I think it's just on the limit of what the Arduino is capable of...
    Bongodrummer
  14. The Following User Says Thank You to Bongodrummer For This Useful Post:
