Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: CIRCLE CENTER FINDER
    The intended application suggests you don't need tenths (or even thousandths) accuracy in locating the center so perhaps a device based on my math post above might work.
    On a metal bar, mount two identical pins about six inches apart on the centerline of the bar. Draw a line on the bar midway between the two pin locations. This is your "chord generator".
    Push it against the circumference of the disk until the pins touch. Lay a machinist square on the top of the bar, align with the center mark and draw the bisector on the disk. Repeat. The center is the point where the two lines cross.
    It's just a gedanken-design but it might inspire you in your build.
    I like that "chord generator". Akin what tool gunsmiths use to mark centerline of shotgun ribs for beads, woodworkers use a larger version to bisect material. Both are identical to your example; with a hole mid-point twixt the dowels, sized for transfer punch of choice.
    Math and geometry are fine, and I use them regularly. Plates too rusty to scribe with nice old M&W dividers.
    But constructing a center finder, I can do wearing gloves and cold weather gear.
    It's 21F degrees outside and a couple colder in the building; Wednesday 17F. In the spring I anticipate 375K BTU boiler to arrive and plumb iron radiators I've collected. Several tons of machinery make excellent heat batteries. Next year I'll be working down there any time I dang well please!
    Download plans for marking gauges.
  2. #12
    Make your "chord bar" with lots of holes and several pin sizes and you've got a dual purpose tool, e.g.,
    http://www.homemadetools.net/forum/l...r-finder-27455
    In that thread, Paul Jones asked the purpose of the brass bar along the edge of the tool and I remarked that I had forgotten why I put it there.
    This thread has reminded my aging brain why I did that. Of course, it marks the perpendicular bisector of the chord when the bar is used as described in my last post to find the center of circles.
    In deference to your sensibilities I won't report the temperature here in LA. Let's just say the only white we'll have for Xmas will be the surf at the beach. See for yourself...
    https://eatgoodstuff.com/resources/strandcam/
  3. #13
    That dodge won't work. Dad and two sisters live there...They've already called to gloat.
    My sensibility is shored up by one thing; only place with an affordable right-sized building. And a nice old [1902] home across town for Ms. Toolmaker. Sounds like two, a package counts as one IMHO.
  4. #14
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    Now I know why you have a photo of Einstein as your avitar........smart guy.
  5. #15
    LyleD's Avatar
    Apr 2017
    South Africa
    Hi Captainleeward,
    Thank you for sharing. A very nice piece of kit to have in the workshop.
    Regards,
    Lyle
  6. The Following User Says Thank You to LyleD For This Useful Post:
    PJs (May 9, 2018)
  7. #16
    Jul 2014
    My pleasure I'm sure....Cap
  8. The Following User Says Thank You to Captainleeward For This Useful Post:
    PJs (May 9, 2018)
  9. #17
    Raytonian's Avatar
    Apr 2018
    Raytonian's Tools
    Very useful, thank you.
