Results 1 to 4 of 4
Thread: Cheapest adjustable angle plate on Amazon
    Supporting Member theeddies's Avatar
    Mar 2019
    Georgia, US
    theeddies's Tools
  2. The Following 7 Users Say Thank You to theeddies For This Useful Post:
    carloski (Mar 23, 2021), lassab999 (Mar 24, 2021), mklotz (Mar 23, 2021), mwmkravchenko (Mar 23, 2021), nova_robotics (Mar 23, 2021), rlm98253 (Mar 23, 2021), Tonyg (Mar 23, 2021)
    Mar 2019
    Georgia, US
    theeddies's Tools
    Might make a good base for mods, etc.
    Some remarks...
    Handle hits table - drive table angle screw with an appropriate socket driven by an electric screwdriver.
    Slippage when adjusting - tighten the lock screws a bit to provide some drag on the table movement
    Accurately setting angle - use an electronic angle gauge or, for real precision, a sine bar
    Good luck with your new toy.
  5. The Following User Says Thank You to mklotz For This Useful Post:
    theeddies (Mar 23, 2021)
    Mar 2019
    Georgia, US
    theeddies's Tools
    Hello,
    Thanks! The more I think about it I will probably remove the screw all together (it is just bolted on) to get full movement. I should have mentioned in the video that just about any tension on the bolts jams up the table movement. Could probably shape the nuts to alleviate that. The electronic level I use at the end is more than likely accurate enough for most of what I do, though I have a sine bar for when I want to feel like a professional, lol. Thanks!
