Thread: Cheap Peristaltic Pump for Mill Cutting Fluid
    Sep 2018
    nova_robotics's Tools
    I just put this together and it works fantastic. This little modification allows you to meter oils or other cutting fluids into the airstream of a cooling air nozzle. You can go from zero (straight cooling air) to a fire hose of coolant. Also it allows the use of pure coolant with no air supply. This was a very cheap and simple modification that I should have done years ago. It worked out so well that I'm going to be installing a similar setup on my lathe.
  2. The Following User Says Thank You to nova_robotics For This Useful Post:
    DIYer (Sep 25, 2023)
    Thanks nova_robotics! We've added your Mill Pump Modification to our Machining category,
    as well as to your builder page: nova_robotics's Homemade Tools. Your receipt:
