Results 1 to 4 of 4
Thread: Charge air cooler pressure test cap
    A truck came in with the complaint of no boost pressure
    the first thing I did was to make a test cap to use my air compressor to find where the problem was.
    I used a standard rubber plumbers cap to block off one tube at the turbo then cut a length of 3" PVC and cemented a cap to it then drilled the cap and installed a Schrader valve After applying air pressure I determined the cooler itself had been damaged in the recent accident So I replaced the cooler.Charge air cooler pressure test cap-img_20231116_142842cc.jpg
  2. The Following 3 Users Say Thank You to Frank S For This Useful Post:
    Jon (Dec 14, 2023), mr mikey (Dec 13, 2023), nova_robotics (Dec 17, 2023)
    Thanks Frank S! We've added your Charge Air Cooler Pressure Test Cap to our Engine category,
    Supporting Member mr mikey's Avatar
    May 2022
    Michigan
    mr mikey's Tools
    I have done this many times myself. Between all the guys in the shop we had quite an assortment of sizes. Thanks for your post.
    Quote Originally Posted by mr mikey View Post
    As it turned out there was a long crack in the top of the cooler that one could have been welded but I noted that it looked like some of the tubes were cracked as well.
    I have his truck back together with the new parts, but we still haven't received the insurance check yet
    mr mikey (Dec 14, 2023)
