Page 3 of 3 FirstFirst 1 2 3
Results 21 to 24 of 24
Thread: Chamfering Machine
  1. #21
    Jan 2018
    petertha's Tools
    Quote Originally Posted by wizard69 View Post
    All this has me wondering if adding a flinger to the vertically mounted arrangement would do enough to keep the swarf away from the open windings.
    I'm not sure if you clicked on the link I provided in earlier post but there is an example of Stefan's chamfering machine setup, a die grinder in vertical mode. Here it is again
    Chamfering machine
    He milled a port in the side of the body & that's where chips stream out. I think I recall in one of his YouTube videos showing it in action & he may have it manifolded to a vacuum, I cant recall. Its a torrent of chips.
    Just to be clear, I don't think die grinders are 'as' susceptible to chips in the motor windings. The vents are well back & smaller & its (somewhat) made for duty like this. Anyway on my tool, its very well protected & chips drop into a natural made cavity. The reference I was making was my first attempt - an inverted router. Routers breath differently to die grinders because a) they are intended for wood so sawdust isn't as problematic and b) mostly cut bit down & cooling fan blows out. Basically a good portion of the motor is open vents. Even when the bit points up like in a router table setup, there is usually a collet or similar closure. Anyway I viewed a metal shaving environment as more hostile to motor windings to a router.
  2. The Following User Says Thank You to petertha For This Useful Post:
    Captainleeward (Mar 13, 2018)
  3. #22
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    petertha, Ok I am hooked I am going to make one this month after I get the solid rod aluminum.
    My congrats for a well thought out build, many a time when I am using my belt sander to do the edges,
    I wish I had a device as you have built good job...Cap..
  4. The Following User Says Thank You to Captainleeward For This Useful Post:
    Paul Jones (Mar 13, 2018)
  5. #23
    Dec 2017
    Cape Coral, FL
    old_toolmaker's Tools
    petertha,
    This is a very nice concept for a chamfering machine. It is similar to a machine (Burr Beaver) we had years ago in the shop. We used it to chamfer steel mold plates. Your version is well designed and executed and it is portable.
    Dick
    Links to some of my plans:
  6. #24
    Jan 2018
    Black Mountain Queensland
    ranald's Tools
    I'm with you Paul & Nelson, for the use of quality PPE. During the late 80's I subcontracted in Parks maintenance and the contracter hired an experienced chap who had no bridge on his nose and would not wear safety glasses. I told him HE HAD TO! He refused stating he didn't during the 8 1/2 years with his previous employer for whom the contractor was working. I presumed they let him go because of this as he was very good at his work. I compromised with him and stated that he could wear my "racing goggles" if he wanted to work. He couldn't believe how well they fitted his face and the "spongy material filled the void where he had no nose bridge. win win win!(except my financial cost but I had peace of mind about my work colleague's eyes). I knew a safety officer supervising over 600 staff safety and he lost an eye on his own yard . He missed one blade of grass and picked up the line trimmer & cut that one blade taking out his eye: he had forgotten he had removed his PPE.
    Interestingly, in 1999 I found employment with a local goverment and had to sign an agreement(after passing the medical including eyes & hearing) that stated Ithey would own any invention I made while working there=very ambiguous relative as to what invention. I continually complained about the quality of the ear plugs they allocated and eventually used my own quality muffs for protection. After others complained also, the ear tests were done again and mine had deteriated in the four years. They brushed off the matter suggesting my out of work hours work may have caused the decline or my muffs may have been faulty.
    The best protection is the minimum in my humble opinion so don't settle for second best.
    Regards,
    Ranald
