Thread: Centering Dial Indicator
    Jul 2020
    Malta
    johncg's Tools
    Recently had to use the rotary table on the milling machine but did not have enough headroom to center it with the co-axial indicator. My milling table is mounted on a circular column so there is no possibility to lower it down, indicate and putting it up again without loosing the centering. Came up with the idea to use a 30mm range dial indicator. Unscrewed the tip and made a quick perpendicular extension enough for clearance. Worked beautifully. Can indicate holes ranging from around 50mm to 110mm diameter.
  2. The Following 5 Users Say Thank You to johncg For This Useful Post:
    bustre00 (Sep 26, 2021), Home-PC (Sep 27, 2021), Jon (Sep 30, 2021), metric_taper (Sep 26, 2021), NortonDommi (Sep 24, 2021)
    Thanks johncg! We've added your Dial Indicator Offset Extension to our Measuring and Marking category,
    as well as to your builder page: johncg's Homemade Tools. Your receipt:
    New plans added on 12/18/2024: Click here for 2,637 plans for homemade tools.
